Cauchy sequence; I need some help
  • Thread starter Thread starter ╔(σ_σ)╝
    Cauchy Sequence
The discussion revolves around a problem involving a Cauchy sequence, specifically examining the conditions under which such a sequence converges to zero. The original poster expresses confusion regarding the implications of the Cauchy property in relation to the convergence of the sequence.
  • Participants explore the relationship between the Cauchy condition and the convergence of the sequence to zero. Questions arise about the necessity of the Cauchy property, the meaning of the inequality given in the problem, and the implications of finding a single index where the sequence meets the criterion.
Some participants have provided clarifications regarding the distinction between finding a single index satisfying the condition and the requirement for all subsequent indices. Others have suggested that a subsequence converges to zero, prompting further exploration of how this relates to the original sequence's convergence.
There is an ongoing discussion about the implications of the Cauchy condition and the nature of convergence, with some participants questioning the completeness of the information provided in the problem statement.
╔(σ_σ)╝
Let [tex]x_{n}[/tex] be a Cauchy sequence. Suppose that for every [tex]\epsilon>0[/tex] there is [tex]n > \frac{1}{\epsilon}[/tex] such that [tex]|x_{n}| < \epsilon[/tex]. Prove that [tex]x_{n} \rightarrow 0[/tex].
My problem with the question is I do not understand it.
if,
[tex]|x_{n}| < \epsilon[/tex] when [tex]n > \frac{1}{\epsilon}[/tex] ;
Doesn't that mean that [tex]Lim_{n\rightarrow infinity} x_{n} = 0 ?[/tex]
In which case [tex]x_{n} \rightarrow 0[/tex] because if the limit as n goes to infinity is zero, then the terms can be arbitrarily brought close to zero as n gets large enough.
What exactly is the point of me knowing that [tex]x_{n}[/tex] is a Cauchy sequence ?
It doesn't seem like I even need to know that it is a Cauchy sequence. After-all, every convergent sequence is a cauchy sequence.
Am I missing something ?
You only know that there is one n such that [tex]|x_n|<\epsilon[/tex]. You don't know that for example [tex]|x_{n+1}|<\epsilon[/tex]
If we take away the Cauchy condition then the sequence (1,0,1,0,1,0,1,0,...) would fit the criterion
Sorry I don't follow.
Doesn't the inequality hold for every epsilon?
And given that n is not a specific number can't I just make n to be n+1 ?
And given your sequence, if [tex]x_{n} = 1[/tex] the inequality would not hold.
I am a bit lost. Please explain further.
Ok, let's continue with my example.
Let's pick [tex]\epsilon=\frac{1}{100,000}[/tex]. Then we need to find n larger than 100,000 such that [tex]x_n<\epsilon[/tex]. Well that's easy, n=100,002 works, since we know that's zero.
The point is that it doesn't say there exists N, such that for all n>N, |xn|<epsilon, it only says there exists ONE n for which |xn|<epsilon
Basically, the statement of the problem is that a SUBSEQUENCE of xn converges to zero
Okay I understand the problem now. I will think more about the problem and request more help if I need to. Thanks for now. I'll repost if i don't get anywhere.
Okay, I thought about the question and I am still not sure what to do.
Now that I know a sub-sequence in [tex]x_{n}[/tex] converges. So this means the following are true:
1) The Cauchy sequence converges since we have found a convergent subsequence.
2) The Cauchy sequence converges to 0 also , since the terms of the Cauchy sequence can brought arbitrarily close to each other. This is a Lemma in my book anyway; I assume I can use it.
3) since the Cauchy sequence converges to zero this means [tex]x_{n} \rightarrow 0[/tex]How exactly do I go about proving this mathematically ?
Can someone please point me in the right direction?!
You basically have the right idea. If you want to get the sequence within [tex]\epsilon[/tex], pick N so that the elements of your subsequence are within [tex]\frac{\epsilon}{2}[/tex] and the elements of your sequence are within [tex]\frac{\epsilon}{2}[/tex] of each other when the indices are larger than N and see what you can do
UThe elements of the sequence are within epsilon of what? 0? Are you suggesting some sort of triangle inequality ? Something like
[tex]|x_{n}-x_{m}|\leq |x_{n}|+|x_{m}|< \frac{ \epsilon_{0}}{2}} + \frac{\epsilon_{0}}{2}[/tex].
EDIT
I am not sure how to get the terms in the subsequence close to those of the sequence. Can you help me with this?
  • · Replies 28 ·
