| Thread Closed |
Calculation of tank height based on flow rate |
Share Thread | Thread Tools |
| Sep2-10, 06:08 AM | #1 |
hi physics forum
i am having a issue related to a tank size based on the flow rate and the diameter of the orifice. the dimensions would be the total height of the setup should be 1000mm the flow rate should be 525+/- 25ml/min the Internal diameter of the orifice is 4.3mm what would be the probable dimensions of the tank for maintaining the water level. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep2-10, 12:36 PM | #2 |
If the flow rate out of the tank is 525 mL/min then the flow rate in to the tank must be 525 mL/min in order to keep the water level constant. The dimensions and flow rate are already set by you in your problem statement (i.e. 1000-mm height). The height of the fluid column (in part) is what determines the flow rate out of a tank that is open to the atmosphere. The other dimensions of the tank generally do not matter unless the tank has a really small surface area compared to the orifice diameter. CS |
| Sep2-10, 12:49 PM | #3 |
Mentor
| Sep3-10, 10:27 AM | #4 |
I am a head of engineering in a leading medical devices company.
we are designing a system in which our medical device will be continuously under water flow. so the flow rate is given the orifice diameter is given now i want what would be the tank height |
| Sep3-10, 06:03 PM | #5 |
This is a basic fluid mechanics problem. Use Bernoulli's equation and solve for the fluid level height. This link should help: http://www.engineeringtoolbox.com/be...ion-d_183.html CS |
| Thread Closed |
| Tags |
| fluid flow, water |
| Thread Tools | |
Similar Threads for: Calculation of tank height based on flow rate
| Flow rate of a tank with RAMP at the bottom** | Calculus & Beyond Homework | 0 | ||
| Flow rate, time, height in MATLAB???? | Engineering, Comp Sci, & Technology Homework | 0 | ||
| flow rate calculation | General Physics | 3 | ||
| Water Flow Rate From A Tap Attached 2 A Tank | General Physics | 3 | ||
| Rate of flow - height of water problem | Differential Equations | 4 | ||
