Thread Closed
Height at which two balls collide traveling opposite direcitons
Share Thread
Sep2-10, 07:10 AM   #1
Ball A is dropped from the top of a building of height h at the same time that Ball B is thrown vertically upward from the ground. When the balls collide, they are moving in opposite directions, and the speed of A is twice the speed of B. At what height does the collision occur?
2. Relevant equations
Kinematic equations:
Vf=vi+ at
xf=xi + 1/2(vi+vf)t
xf=xi+vi*t+1/2at^2
vf^2=vi^2+2a(xf-xi)
V(ball A) = 2V(ball B)
3. The attempt at a solution
I've done kinematics equations before, but it's been a while and there is a little more involved with this one, as you're looking for the moment of impact's height where the velocity of falling ball A is twice the speed of rising ball B.
I know the velocity of ball A is simply V(Ball A) = -9.8m/s^2*t
Ball B has a velocity of V(ball B) = V-9.8m/s^2*t
The collision must occur before or at the maximum height Ball B can reach with its initial velocity, but since I cant solve for it, I'm not sure what to do.
I'm fairly sure I can set the values equal to each other because of the relationship of V(ball A) to V(ball B) but I'm having trouble conceptualizing, and dont know if they even want an exact or symbolic answer.
V(ball A) = -9.8*t
V(ball B) = (-9.8*t)/2
I need to solve for time to get height, and height to get time. But I don't have any values for velocity. The only value I have is the constant of acceleration and I feel like that isn't enough to work this out.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep2-10, 03:17 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You did the velocities well. Now you need to write equation for the height where the balls meet. They have to be at the same spot at the same time.
Use the initial velocity of B as parameter. It will cancel out. One more piece of advice: use the symbol g, do not plug in the number too early.
ehild
Sep3-10, 07:15 AM   #3
I knew that there was something I was missing out on! After solving for final height for ball a and ball b and setting them equal to each other, it came out to be a symbolic answer: 2/3h of the building. Thanks ehild! I got some good tips for conceptualizing these problems the other day, and not pluging in known values until you've solved algebraically was one of them. =)
Sep3-10, 02:15 PM   #4
Recognitions:
Good work!
ehild
Thread Closed
Tags
balls, collision, falling, kinematics
Similar discussions for: Height at which two balls collide traveling opposite direcitons
Thread Forum Replies
Height of the two balls collision Introductory Physics Homework 1
Light Traveling in Opposite Directions Special & General Relativity 9
Height at which objects will collide Introductory Physics Homework 4
When will both of the balls be at the same height? Introductory Physics Homework 2
Max height-2 balls-1 straight up-the other horizontal at an angle? yikes! Introductory Physics Homework 1
