Calculating Refrigerator Time for 20°C to 7°C
  • Context: High School
  • Thread starter Thread starter Ylle
    Refrigerator
The discussion revolves around calculating the time required for a beverage, such as a glass of water or beer, to cool from an initial temperature of 20°C to a target temperature of 7°C when placed in a refrigerator at 5°C. Participants explore the application of Newton's Law of Cooling to model this cooling process.
  • Some participants suggest using Newton's Law of Cooling, which states that the rate of cooling is proportional to the temperature difference between the object and the ambient temperature.
  • One participant provides the differential equation and its solution, emphasizing the need to determine the proportionality constant k through experimental data.
  • Concerns are raised about the assumptions in the model, particularly regarding the ratio of volume to surface area and whether the model assumes a spherical object.
  • Another participant notes that k will vary depending on the specific container and surrounding conditions, indicating that the model is simplistic and may not account for all variables.
  • A participant questions how to determine k when it appears to depend on the temperature at a specific time, suggesting a potential circular reasoning issue.
  • Clarifications are made regarding the meaning of variables used in the equations, such as Ti representing the initial temperature of the beverage.
Participants generally agree on the applicability of Newton's Law of Cooling but express differing views on the assumptions and limitations of the model. There is no consensus on how to effectively determine the constant k or the implications of varying conditions.
Limitations include the dependence of the cooling rate on the specific container and environmental factors, as well as the need for experimental data to accurately determine the constant k for different scenarios.
Ylle
Well I'm new, and I have a question :)
I've been looking and searching lots of places, but no luck :(
But my problem, which isn't really a problem, it's just something I would like to know :)
I was wondering if there were a formula, that could find out how long time a glass of water or a beer can for example, that got a temperature of 20 degrees Celsius, would have to be in a refrigerator, that got a temperature of 5 degrees Celsius (For example), for it to get the temperature 7 degrees Celsius for example.
I don't know if there is an easy formula for this, but I hope so, and I hope you understand what I mean.
- Ylle
Science news on Phys.org
You could use Newton's Law of Cooling which says that the rate of cooling is proportional to the temperature difference between the object and the ambient temperature:
[tex]\frac {dT}{dt} = -k (T-T_A)[/itex]<br /> <br /> Of course, you'll need a couple of data points to determine the value of the proportionality constant k.[/tex]
d=delta (change in) T=temp
t=time
[tex]T_A[/tex]=ambiant temp.
Just to let you know if you were confused. If you already knew this, sorry for insulting your intelligence. Wasn't meant for that.
Paden Roder
You could apply Newton's Law of Cooling to this problem.
[tex]\frac {dT} {dt} = -k (T-T_r)[/tex]
where T is the temperature of the beer and Tr is the temperature of the refrigerator. The solution to this is
[tex]T(t) =c e^{-kt}+T_r[/tex]
The constants c and k need to be determined. For c let Ti= initial temperature of the beer we get:
[tex]T(0)=T_i = c + T_r[/tex] so
[tex]c = T_i-T_r[/tex]
To get k you will need to find the temperature of the beer after some time has passed, say 10 min. Let T(10) be the temperature after 10 min, solving for k we get.
[tex]k = - \frac {ln \frac {T(10) - T_r} c} {10}[/tex]
now combine the constants and the original solution to find the temperature at any time.
I see nothing in these equations to account for the ratio of volume to surface area. Does this method assume a spherical object? And, would the ratio have negligable effects on beer cans and glasses of soda?
That is why the k needs to be determined by experiment. It will be different for different containers. It will even be effected by near by objects. Say if you place a large block of Ice beside the can vs a pot of boiling water. Or if the can is in a 6 pack vs alone on the shelf. This is indeed a rather simplistic model but such a problem gets vastly difficult in a hurry if you attempt to get detailed.
The k is a bulk parameter determined for a specific situation.
What did you say Ti was. I'm danish, so I don't know so many english physical words. But is it like: C =m*c where c is the c i need (Heatcapacity if you translate it directly to danish), or is it another c ?
And does k need to be determined for every different time you have ?
Because you say: [tex]k = - \frac {ln \frac {T(10) - T_r} c} {10}[/tex] where T(10) is T(t) for 10 minutes: [tex]T(10) =c e^{-k10}+T_r[/tex] or is a constant you can use every time ?
Well, I'm kinda wasted right now, so I excuse my english mistakes :)
Ti is the starting temperature of the beer.
I would say that you need to determine a k for each different type of container or if it is an individual can or a 6 pack. All of the physical constants related to the beer and container are "bulked" together into this single bulk constant which is determined by experiment.
Once you find a k for a particular container and beverage (the type of beer could effect it, say American P*ss vs Guinness) you should be able to make pretty good estimates on the time required to reach drinking temperature.
Hmmm
I was wondering...
You are writing:
And then you are writing:
But how am I suppose to figure out k, when I need T(t) (T(19)) in the formula ? And then I need k in the T(t) formula, so basically it's an evil circel isn't it :confused:
T(19)? ... I'll assume that you mean T(10), this needs to be MEASURED with a thermometer after the beer has been in the refrigerator 10 minutes. The 10 in the denominator is the 10min time. If you measure after 5 min use a 5 in the denominator.
  • · Replies 28 ·
