Calculating Proper Acceleration at Bottom of a Half Light-Year Rocket
  • Context: Graduate
  • Thread starter Thread starter idcavili
    Acceleration Rocket
The discussion centers on calculating the proper acceleration at the bottom of a half light-year tall rocket under constant proper acceleration of 1g. The equation provided, alpha B = (alpha f c^2)/(c^2 - delta alpha f), is utilized to derive the proper acceleration at the bottom of the rocket, which is determined to be approximately 2.06g. The analysis incorporates concepts of Born rigid acceleration and Rindler coordinates, confirming that the rocket's length is permissible within the defined parameters of Rindler horizons.
  • Understanding of proper acceleration in relativistic physics
  • Familiarity with Born rigid acceleration concepts
  • Knowledge of Rindler coordinates and horizons
  • Basic grasp of relativistic equations involving acceleration and light-years
  • Study the implications of Born rigid acceleration in relativistic scenarios
  • Explore Rindler coordinates and their applications in general relativity
  • Investigate the derivation and application of the equation alpha B = (alpha f c^2)/(c^2 - delta alpha f)
  • Learn about the effects of gravitational acceleration on time dilation and spatial dimensions
Physicists, aerospace engineers, and students of relativity who are interested in the dynamics of accelerating frames and the implications of relativistic effects on proper acceleration.
idcavili
Suppose that you are at the top of a (rigid) rocket which is half a light
year tall. If the rocket is accelerating such that your proper acceleration
is 1g,
What is the proper acceleration at the bottom of the rocket?
B =
F c2
c2  F
This is one of the equations given:
It seems that delta alpha f is the difference in accelerations. I can't find any equation that uses the distance. Is it OK to use the distance in this one?
Well, you could make use of the fact that any object undergoing Born rigid acceleration (such that each point has constant proper acceleration, and the length of the object in the instantaneous inertial rest frame of any point on the object doesn't change from one moment to the next) must be at rest in a Rindler coordinate system. An observer with an acceleration A has the Rindler horizon at a distance of c2/A behind them according to the article, and 1G acceleration works out to 1.03 light-years/year2, so the Rindler horizon would be 1/1.03 = 0.97 light-years behind the observer at the top of the rocket, which means it's OK for the rocket to be 0.5 light-years long. In this case the bottom would be at a distance of 0.97-0.5 = 0.47 light-years from the Rindler horizon, which means it should have a proper acceleration of 1/A = 0.47, meaning A = 1/0.47 = 2.12 light-years/year2, or about 2.12/1.03 = 2.06G.
edit: is this a homework problem? If so I guess you'd have to use an equation that was actually discussed in the chapter in which the problem appeared...what are the meanings of the various symbols in the equation you posted?
  • · Replies 50 ·
  • · Replies 75 ·
  • · Replies 33 ·
  • · Replies 36 ·
10K
  • · Replies 84 ·
  • · Replies 33 ·
