Projectile Motion - Only given time and range
The discussion focuses on solving a projectile motion problem where the range is 4.14 m and the time-of-flight is 0.854 s, with gravity set at 9.80 m/s². Participants clarify that despite not having the launch angle or initial speed explicitly provided, the horizontal velocity can be determined using the range and time. By calculating the horizontal component of velocity and the vertical component using the time of flight and gravitational acceleration, both the launch angle and initial speed can be derived effectively.
  • Understanding of basic kinematics principles
  • Familiarity with projectile motion equations
  • Knowledge of Newton's second law
  • Ability to perform vector calculations
  • Study the equations of motion for projectiles
  • Learn how to derive horizontal and vertical components of velocity
  • Explore the concept of independence of motion in projectile dynamics
  • Practice solving problems involving time-of-flight and range
Students in introductory physics courses, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion.
hogrampage
If the range of the projectile is 4.14 m, the time-of-flight is T = 0.854 s, and air resistance is negligible, determine the following. (Assume that the acceleration due to gravity has a magnitude of g = 9.80 m/s2.)
(a) What is the launch angle of the projectile?
(b) What is the initial speed of the projectile?
See below.
I don't even know where to start. The book I have has equations that require either the launch angle or the initial speed, so I have no idea how I could do this without knowing one or the other. I couldn't use any of them since I wasn't given either the launch angle or the initial speed.
I guessed for a and b because I had no idea what to do.
This is the first physics class that I have ever taken, so I have no previous experience with physics, which makes it very confusing for me.
Welcome to PF!
Although you have not been given either the initial speed or the launch angle, you have been given other equivalent information that will allow you to determine both. For example, you know that for a projectile, the motion in the horizontal (or "x") direction is totally independent of the motion in the vertical (or "y") direction. This independence holds true because the only force acting, namely gravity, is entirely in the vertical direction. Therefore, the only acceleration that can occur is in the vertical direction (recall from Newton's second law how the acceleration depends upon the force). Do you understand?
What this means is that there is no horizontal acceleration. Therefore, the horizontal velocity must be constant. It does not change -- whatever it was initially, is what it is throughout the flight. Furthermore you KNOW what it was initially. It may not be given to you explicitly, but you know implicitly that the horizontal speed must be whatever speed results in a distance traveled of 4.14 m in a time interval of 0.854 s. (This follows because the range of a projectile is defined as the horizontal distance it covers.) In other words, you can combine the range and the flight time in order to determine the horizontal or x-component of the velocity.
In a similar manner, you can combine the flight time with your knowledge of the vertical acceleration in order to figure out what initial vertical speed it must have had in order for it to stay in the air for 0.854 s before hitting the ground again. Once you've solved for that, you'll have both the vertical and the horizontal components of the velocity. Therefore, you'll know everything there is to know about the initial velocity vector, both its magnitude (which is being asked for in part (b)) and its direction (which is being asked for in part (a)).
28K
