Solving Problems with Thevenin: Is My Teacher Wrong?
  • Thread starter Thread starter ottjes
    Teacher Thevenin
The discussion revolves around applying Thevenin's theorem to analyze electrical circuits involving resistors and voltage sources. The original poster presents a problem from a test involving specific resistor values and voltage, questioning the correctness of their approach compared to their teacher's expected answers.
  • The original poster attempts to calculate Thevenin equivalent voltage and resistance using different methods, questioning the impact of resistor configurations on their results. Some participants explore the validity of the original poster's calculations and interpretations of circuit configurations.
Participants are actively engaging in clarifying the calculations and assumptions made by the original poster. There is a mix of agreement and differing interpretations regarding the application of Thevenin's theorem, with some suggesting corrections to the original poster's formulas.
There are references to specific resistor values and configurations that may not be fully detailed in the discussion. Some participants express confusion over the expected answers from the teacher, indicating a potential misalignment in understanding the problem setup.
ottjes
Have some problems with thevenin (or my teacher is wrong, which i believe :)).
[PLAIN]http://www.fmf.nl/~wim/studie/cir1.png
example from my book:
Vi=15V, R1=6, R2=R3=3
Voc = Vi R2/(R1+R2) = 5 V (potential divider)
R2//R3=1.5 Ohm
R1+(R2//R3)=7.5 Ohm --> I = 15/7.5 = 2 A
Cause R2 and R3 are equal half of this current will flow to R2 and other half to R3 -->Isc = 1 (how will this change if R2 != R3?)
R = Voc/Isc = 5/1 = 5 Ohm
How i will solve this problem:
Leave R3 first out of the problem
R1//R2 = (R1+R2)/(R1R2) = 9/16=2 Ohm
Now i have this:
http://www.fmf.nl/~wim/studie/cir2.png
R=(R1//R2)+R3=2+3=5 Ohm
This looks good, same as the book
On my test i got this question:
With Vi=10 V and
R1=R2=R3=5 Ohm
Answer here must be, according to teacher: Voc=5V and R=3.75 Ohm
If i do this the same way as the book:
R2//R3=2.5 Ohm
R1+(R2//R3)=7.5 Ohm --> I = 10/7.5 = 1.33 A
Cause R2 and R3 are equal half of this current will flow to R2 and other half to R3 -->Isc = 2/3 (how will this change if R2 != R3?)
R = Voc/Isc = 5/(2/3) = 7.5 Ohm (This is 2*3.75 :?)
Doing it my way:
R1//R2 = (R1+R2)/(R1R2) = 10/25=0.4 Ohm
R=(R1//R2)+R3=0.4+5=5.4 Ohm (different than the other answers :?)
What am i doing wrong, What is the good way to do this
edit: fixed url's
Hi ottjes,
sorry I don't see what your teacher wants from you. Could you please explain?
from the second circuit i got 3 different answers, i want to know which one is the right one? and if possible what is wrong about the others
I can only see the 1st picture, the other link produces a server error.
Do they want you to find the total resistance R of the circuit?
If yes, I should say R = R1 + R2, since no current can go thru R3.
fixed the url
the meaning of thevenin is that you can big circuits very small, ie a circuit that contains only a resistor and a voltagesource (thevenin), or a circuit with a resistance and a current generator (norton)
example:
calculating voltage across A and B of this circuit is diffucult
http://www.phys.rug.nl/pleit/electronics/O00b1{image0}.gif
after applying thevenin and norton a few times you see that the circuit is above is equil to:
http://www.phys.rug.nl/pleit/electronics/O00b1{image4}.gif back to my question, anybody knows what i did wrong?
In your original post, this is the first line that looks false.
Because in the 1st picture, R1 and R2 are not parallel.
they are cause i left R3 out of the circuit there, not the wire there
edit: post 5K
Ah! Now I think I understand what happens.
I wrote down all the Kirchhoff rules that apply here, and worked it out. I found that you can indeed replace this by just Voc and R. My result was:
Voc = Vi * R2/(R1+R2)
R = (R1||R2) + R3.
I think these are the same as your formulae.
Now your error is probably here:
Should read:
R1||R2 = (R1R2)/(R1+R2)=25/10 Ohm = 2.5 Ohm
So, R = 7.5 Ohm.
I think you are correct and 3.75 Ohm is wrong.
I got the same answer that you did...
First step, disconnect R3 from the circuit.
Vth is the voltage across R2, which would be 5V.
Rth is found by treating the two resistors as if they were in parallel...
Rth = 1/(1/R1+1/R2) = 2.5 ohms.
If you then re-hook up R3, you find total resistance of the circuit
Rtot = Rth + R3 = 7.5 ohms
and IR3 = Vth/Rtot = 2/3 A
EDITED to make it more readable
Thanx all, glad to know i did understand it ;)
My fault was that i did R=1/R1 + 1/R2 which is (R1+R2)/(R1R2)
But R = 1 / (1/R1 + 1/R2) which is (R1R2)/(R1+R2)
  • · Replies 18 ·
