Spring-Mass System: Treating 2 Identical Springs
  • Thread starter Thread starter colonel
    System
The discussion revolves around a spring-mass system involving two identical springs and how to treat their configuration, specifically whether they are in series or parallel. Participants explore the implications of Hooke's law in this context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the treatment of springs in series versus parallel, questioning how the effective spring constant changes based on their arrangement. There are attempts to derive relationships between forces and displacements in both configurations.
The discussion is active, with participants providing insights into the behavior of springs in different configurations. Some guidance has been offered regarding the effective spring constant when springs are arranged in series, but questions remain about the role of each spring in the system.
There is an ongoing exploration of the assumptions regarding the arrangement of the springs, including whether they are vertical or horizontal, which may affect the analysis. Participants are also considering the implications of spring constants and forces in their reasoning.
colonel
Hi, in a simple spring-mass system consisting of two identical springs, how would you treat the springs? Would Hookes equation be F = kx + kx?
Are they in series or parallel?
Tides point is that if you attach two identical springs end to end, effectively you still have just one spring (of twice the length) still with spring constant k.
If you have two identical springs side by side (and both attached to the mass) then the act identically and then you can add them.
Exactly - except - the spring constant of a spring varies inversely with its length! This means that placing two identical springs in series you now have a single spring with half the effective spring constant.
To see this, consider two spring with constants [itex]k_1[/itex] and [itex]k_2[/itex]. Since the springs exert identical forces on each other we have [itex]k_1 \Delta x_1 = k_2 \Delta x_2[/itex] where the [itex]\Delta[/itex]'s measure the compression or expansion of each spring. Also, [itex]\Delta x_1 + \Delta x_2 = x[/itex] the displacement of the combined spring.
The force exerted by the combined spring is [itex]-k_2 \Delta x_2[/itex] and using the relations above you can see that [itex]F = - \frac {k_1 k_2}{k_1+k_2} x[/itex]
Let us hang a mass M from spring 1: so, k1 x1=Mg.
Let us hang a mass M from spring 2: so, k2 x2=Mg.
If we hang the mass M from the springs arranged in series,
we have an effective spring with spring constant K and displacement X=x1+x2.
Since KX=Mg, we find
x1 = KX/k1 and
x2 = KX/k2.
By adding,
X=x1+x2=KX(1/k1 + 1/k2)
or
K=(1/k1 + 1/k2)-1
When k1=k=k2, we have K=k/2.
Edit:
Here's a quick proof using force and energy (instead of displacement).
k1 x12/2+k2 x22/2=KX2/2.
That is,
(k1 x1)2/k1+(k2 x2)2/k2=(KX)2/K.
Since KX=k1 x1=k2 x2 for springs in series,
(1/k1+1/k2)=1/K.
x1 = KX/k1 and
x2 = KX/k2.
What if the springs aren't hanging but are placed horizontally?
Why is this: "The force exerted by the combined spring is -k_2 \Delta x_2" ? Wouldn't the other spring also play a role?
  • · Replies 22 ·
  • · Replies 18 ·
