| Thread Closed |
Propane in a Container finding pressure and energy |
Share Thread | Thread Tools |
| Sep7-10, 10:11 PM | #1 |
An aluminum bottle weighs 10 kg when empty and has an internal volume of 20 liters. It is filled with 5 kg of propane (C3H8) at 24 °C. The aluminum bottle is rated for a maximum pressure of 35 bar at which point a relief valve is opened. a) What are the initial pressure, quality, and internal energy? b) What temperature will the bottle reach at maximum pressure as it is heated? What is the quality at this maximum pressure state? c) The relief valve remains opened until the pressure falls back to 14 bar. If the mass of propane remaining in the bottle is tenth of its original value, what is the temperature of the propane upon shutting of the relief valve? 3. The attempt at a solution All I want are the equations I need and how to set the problems up |
| Sep11-10, 02:37 AM | #2 |
Recognitions:
For the first part you can use PV=MRC3H8T to get P.
Neglecting the weight of the Al, if it weighs 10 kg when empty (no C3H8), and then is filled with 5kg of C3H8, how much air is in it? You should now be able to find the quality. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Propane in a Container finding pressure and energy
| Air pressure in a container then released | Introductory Physics Homework | 3 | ||
| Pressure of gases in a container | Classical Physics | 1 | ||
| pressure at the bottom of a container | Introductory Physics Homework | 1 | ||
| Effect of Atmospheric pressure on Butane /propane | General Physics | 0 | ||
| Force due to pressure on side of a container | Introductory Physics Homework | 6 | ||
