Tracking a Space Ship: Will an Asteroid Hit the Target?
The problem involves determining the trajectory of a spaceship and an asteroid in space, represented by parametric equations. The original poster seeks to find out if the asteroid will collide with the ship and, if not, how close they will come to each other.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the parametric equations for both the ship and the asteroid, with one participant expressing uncertainty about how to begin solving the problem. There is mention of using optimization to find the minimum distance between the two paths.
The discussion is ongoing, with participants exploring different approaches to the problem. A hint regarding the distance between the ship and asteroid at time t has been provided, which may guide further exploration of the problem.
One participant notes a hint from their homework about the relationship between non-intersecting lines and parallel planes, indicating a potential avenue for exploration regarding the proximity of the two trajectories.
mjbourquin
This problem is a sample flight path of a ship in space.
Its path is described by the line r(t) = (-1+t)i + (2-t)j
An asteroid has the starting point (0, 5, -1) and a heading vector of 2i + j + 3k
Ship
x = -1 + t
j = 2 -t
z = 0
asteroid
x = 0 + 2t
y = 5 + t
z = -1 + 3t
The question is will the asteroid hit the ship and if not how close will they come.
We do not do your homework for you at this site. We help you do your own homework. Before we can even start offering help you need to have shown some work on the problem.
I don't even know how to start. A hint in my homework states that if two lines do not intersect, they can be embedded in parallel planes but I don't know how that helps me find how close two lines come to each other. If they do intersect I would plug both lines into an r(t) and set them equal. Then find t. Is that right.
Hint: What is the distance between the ship and asteroid at time t? What is the minimum of this distance?
oh, I forgot all about optimization derivatives. Much easier. Thanks.
  • · Replies 21 ·
