Visual J#: Getting Started with 2005 Express Edition Beta
  • Thread starter Thread starter UrbanXrisis
    Visual
The discussion focuses on the challenges faced by a user transitioning from BlueJ to Visual J# 2005 Express Edition Beta. The user encounters a compilation error stating "No source file supplied" when attempting to run a simple program that calculates powers of two. The provided code compiles successfully in Sun Java but requires adjustments to work in J#. Key insights include the need for proper project setup and understanding of J# syntax differences.
  • Familiarity with Java programming concepts
  • Basic understanding of Visual J# 2005 Express Edition Beta
  • Knowledge of compiling and debugging Java applications
  • Awareness of differences between Sun Java and J# syntax
  • Explore Visual J# project setup and configuration
  • Learn about J# syntax and its differences from standard Java
  • Research common compilation errors in Visual J#
  • Examine sample code for Visual J# to understand best practices
Java developers transitioning to Visual J#, students learning J# programming, and anyone troubleshooting compilation issues in Visual J# 2005 Express Edition Beta.
UrbanXrisis
I'm new to using Visual J# and I have not a single clue of how to use it. I've been using BlueJ for compiling Java but I'm tring J# now. I have Visual J# 2005 Express Edition Beta all up and running, now I want to compile something but I don't know where to begin. I tried to compile something but the debugger always tells me that "No source file supplied." Does anyone have some basic code that I can compaire my code with or any hints to help me out in this situation? Thanks
Computer science news on Phys.org
For example, I could not
get this code to compile:
class program5 {
public static void main(String args[ ]) {
int result=1,digit=1;
do {
if (digit<7000){
System.out.print("2 to the power of "+digit+" = "+result+"\n");}
result=result*2;
digit++;
}while (result<70000);
This compiles of course under Sun Java. How do I do the same with J#?
12K
  • · Replies 0 ·
  • · Replies 23 ·
13K
