How Long for an Electron to Move 1cm in a Silver Wire?
The discussion focuses on calculating the time it takes for a conduction electron to move 1 cm in a silver wire with a diameter of 1 mm and a current of 130 mA. The drift speed was initially calculated using the formula Vd = I / (Ne * A), where Ne is the density of conduction electrons (5.8 x 10^28 m^-3) and A is the cross-sectional area of the wire. The correct drift speed is 2.8538e-22 cm/s, leading to a time of approximately 5.84e19 minutes for an electron to traverse 1 cm. The key error identified was in the conversion from meters to centimeters.
  • Understanding of drift velocity calculations in conductive materials
  • Familiarity with the formula Vd = I / (Ne * A)
  • Knowledge of the charge of an electron (q = 1.6 x 10^-19 C)
  • Basic unit conversion between meters and centimeters
  • Study the principles of drift velocity in conductors
  • Learn about the relationship between current, charge, and electron density
  • Explore advanced calculations involving electron mobility in various materials
  • Investigate the effects of temperature on conductivity and drift speed
Students and professionals in physics, electrical engineering, and materials science who are interested in understanding electron movement in conductive materials and the principles of electrical current.
GreenDinos
A silver wire of diameter 1 mm carries a current of 130 mA. The density of conduction electrons in silver is 5.8X10^28 m-3. How long (on average) does it take for a conduction electron to move 1.0 cm along the wire?
ok, so first I calculated drift speed using the equation Vd = I/ Ne * A
for Area, I just used pi*r^2
I set it up Vd = .130A/ ((5.8e28 m^-3) x (7.853e-7 m^2)) and got the drift speed to be 2.8538e-24 m/s
I then set up 2.8538e-24 m/s x 100cm/m x 60sec/min and got
1.71228e-20cm/ min .
To get minutes for one cm i took
1cm/1.71228e-20cm/ min and got 5.840e19 minutes to move one cm.
i'm obviously doing somehting wrong because it's not accepting my answer. Is there something I'm missing??
You left out the charge of the electrons. Neglecting signs,
[tex]v_d=\frac{I}{A q N_e}\mbox{ , q = }1.6\cdot10^{-19}\mbox{ C. }[/tex]
ehild
Hi there,
I can see that you have correctly calculated the drift speed of the conduction electrons in the silver wire. However, there may be a mistake in your conversion from meters to centimeters. The drift speed you calculated is in meters per second, so when converting to centimeters, you should use a conversion factor of 100 (not 100cm/m). This would give you a drift speed of 2.8538e-22 cm/s.
Using this value, the time taken for a conduction electron to move 1 cm along the wire would be:
1cm / (2.8538e-22 cm/s) = 3.504e21 seconds
This is a very large number, so it is often more convenient to express it in a different unit, such as minutes or hours. To convert seconds to minutes, you can divide by 60, so the time taken would be:
(3.504e21 seconds) / 60 seconds/min = 5.84e19 minutes.
I believe your answer was correct, but there may have been a mistake in the conversion from meters to centimeters. I hope this helps clarify and if you have any further questions, please let me know.
11K
10K
10K
