| Thread Closed |
Solve for x in terms of y (Quadratic formula) |
Share Thread | Thread Tools |
| Sep12-10, 02:14 PM | #1 |
Use the quadratic formula to solve the equation for (a) x in terms of y and (b) y in terms of x. 2. Relevant equations 4x^2 - 4xy + 1 - y^2 = 0 3. The attempt at a solution I am not really sure where to start at all. If I could just figure out the values for a, b, and c of the quadratic formula then the rest would be simple (for me). Do you take the values from the current equation like this? a = 4, b = -4y, c = 1 - y^2 I feel as if I am over analyzing this problem. If anyone could point me to a start that would be greatly appreciated. There are no examples from my textbook that pertain to this exact type of problem. |
| Sep12-10, 02:17 PM | #2 |
Yes, you got it.
| Sep12-10, 02:42 PM | #3 |
Thank you for the quick reply. I did run into one more issue with this problem. After plugging in the values into the quadratic formula, I run into this step:
(4y +– sqrt(32y^2 - 16)) / 8 There are numbers inside the sqrt that I could pull out: 32 and -16. My next planned step it to re-arrange the values inside the sqrt as follows: 1) sqrt(32y^2 - 16) = sqrt((16)(2y^2) - (1)(16)) 2) (16) * sqrt(2y^2 - 1) This doesn't seem right though. I keep looking for an example, definition, rule, or law to use in this scenario but can't seem to think of one. EDIT: Actually, it seems right now that I factored correctly. 1) sqrt(32y^2 - 16) = sqrt((16)(2y^2 - 1)) 2) (16) * sqrt(2y^2 - 1) Then the whole formula will look something like this: (4y +- 4 * sqrt(2y^2 - 1)) / 8 I can then reduce the fraction to (y +- sqrt(2y^2 - 1)) / 2 I think I've got it! This problem has been stopping me for a while now. |
| Sep20-10, 05:10 PM | #4 |
Correct! Now, you've solved half the problem (you've solved for x in terms of y) ... you still need to solve for y in terms of x
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solve for x in terms of y (Quadratic formula)
| How do you interpret quadratic terms in the gauge field in a Lagrangian? | High Energy, Nuclear, Particle Physics | 2 | ||
| Are all quadratic terms in gauge fields necessarily mass terms? | Quantum Physics | 0 | ||
| Do you need to use the quadratic formula to solve for the unkown? | Precalculus Mathematics Homework | 6 | ||
| Solve For B In Terms Of A | Precalculus Mathematics Homework | 10 | ||
| could someone solve for s/p (or p/s) in terms of v? | General Math | 1 | ||
