Local Realistic in 4-Space Sliced to 3+1 Nonlocal
  • Context: Graduate
  • Thread starter Thread starter inflector
    Local
This discussion explores the reconciliation of local realism with violations of Bell's Inequalities through the concept of 4-space and its 3D slices. The author presents a model using a 2D slice of an elastic tube, illustrating how changes in one closed curve can causally affect another, despite appearing disconnected in 2D. The discussion suggests that entanglement may involve causal connections that are local in 4-space but appear nonlocal in 3-space, raising questions about the nature of superluminal effects. The Holographic Principle is mentioned as a modern approach to understanding these phenomena.
  • Understanding of Bell's Inequalities
  • Familiarity with wave equations in physics
  • Knowledge of the Holographic Principle
  • Concepts of local realism and nonlocality in quantum mechanics
  • Research "Bell's Theorem and Local Realism" for foundational knowledge
  • Study "Wave Equations in Elastic Materials" for practical applications
  • Explore "The Holographic Principle in Quantum Gravity" for advanced theoretical insights
  • Investigate "Entanglement and Superluminal Communication" for implications in quantum mechanics
Physicists, quantum theorists, and researchers interested in the intersections of quantum mechanics, local realism, and higher-dimensional theories.
inflector
I've been exploring an idea for reconciling the possibility of local realism with the various experimental proofs of violations of Bell's Inequalities. Since it seems like an idea that must have been explored and considered elsewhere, I am looking for relevant papers which have considered the idea before. I haven't found any yet, but I feel like there must be some as it seems like a rather obvious idea so there must be some error in the logic of it or I would have seen it before.
Consider a 2D slice of an object that exists in 3-space, an elastic tube where the 2D slice shows only two closed curves, C1 and C2 which are not connected in any way, the change in size and shape in a continuous fashion over time, i.e. For the sake of the example, consider that the tube vibrates according to wave equations that are well known. An observer in 3-space could determine the relationship between the shapes of a particular slice according to this set of equations.
If you only had access to the 2D slice, you would not easily see any connection between the two closed curves C1 and C2, yet one exists. There is in fact a causal connection to changes in the curves. If you changed one of the curves, say C1, by applying a force to the edge of one of them there would be a corresponding vibratory change in C2 at some later point. The delay in the change would appear to be random if you only had access to the time-evolving curves in 2-space since there would be no way of knowing how far apart the two curves were in 3-space. Some might even say that the curves were "entangled" in some way.
If the 2D slice were itself curved, it would be possible to have C1 and C2 located much closer in 3-space than they would be in the 2D slice. You can see how this would work if you took a 3-ring hole-punched paper and curved it back so that two holes are penetrated by a single pencil, they holes might be 10mm distant in 3-space (i.e. nearly adjacent on the pencil) but 300mm apart in the curved 2D slice represented by the piece of paper. In this instance, a change in one of the curves might cause an affect in the other curve that appeared to be super-luminal since the distance traveled by the cause in 3-space was much shorter than the distance traveled in the 2D slice. It might even be fast enough to seem to be "spooky action at a distance".
I am trying to find threads here or papers on the subject of an analogous 3D slicing of a structure that existed in 4-space where the causal connections exist in 4-space but might not be visible or apparent in the 3D slice, and the idea that entanglement might involve causal connections that appear to be superluminal in the 3D-slice, i.e. nonlocal in 3-space but that are in fact, local and sub-luminal in 4-space.
Any pointers to relevant papers would be greatly appreciated.
No one has seen anything like this before? Or finds any obvious problem in the above logic?
This sure seems like an idea that must have been considered somewhere.
That sounds like wormhole type constructions to argue for non-locality, problem is it doesn't explain how non-local correlations may exist anywhere in the universe in any direction, unless you can find some pretty exotic embedding in the higher dimensional space to argue otherwise.
The Holographic Principle is a modern attempt at this type of argument, you may have local connections on the holographic boundary associated with non-local causal events in the (higher dimensional) bulk space.
eg http://www.springerlink.com/content/67q829q31m5qrg11/ (arXiv)
It's all pretty speculative.
Graduate Knots In 4D
  • · Replies 74 ·
  • · Replies 25 ·
  • · Replies 87 ·
9K
