General Acceleration/Tension Question
  • Context: Undergrad
  • Thread starter Thread starter mohabitar
    General
The discussion centers on the relationship between acceleration and tension in a string connecting two objects. It is established that if two objects are connected by a massless string and are accelerating equally, the tension in the string remains constant. However, when one object begins to accelerate, the tension changes based on the forces acting on the masses. Specifically, in equilibrium, the tension is calculated as T = m2 * g, while if mass 2 accelerates downward, the tension is T = m2 * g - m2 * a, indicating a decrease in tension.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of tension and equilibrium in physics
  • Basic knowledge of mass and gravitational force calculations
  • Comprehension of acceleration and its effects on connected systems
  • Study the principles of Newton's second law of motion in detail
  • Explore the concept of tension in non-equilibrium systems
  • Learn about massless strings and frictionless pulleys in physics problems
  • Investigate real-world applications of tension in mechanical systems
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of connected objects in motion.
mohabitar
Ok so I made an observation while answering some homework questions, and I want to make sure its not just a coincidence.
If I have something like this:
Since their acceleration is equal in this case, will tension of the string always be equal? Say the table is lifted at a different angle, where the blocks start moving in the opposite direction of the first example, since their acceleration is equal again in this case, will tension be equal as well? Can we generalize that to all examples, where if two objects are held together by a string and their acceleration are the same, then the tension is also the same?
As long as the string is massless and the pulley is massless and frictionless, then the tension will be the same throughout the string.
The tension will be deferent depending if the bodies are accelerating or not.
For example, when the system is in equilibrium the tension is ( T=m2*g ).
If mass 2 starts moving down, the tension in the string will be ( T=m2*g-m2*a ) so less than when the system is in equilibrium.
And yes the tension will be the same throughout the string.
I hope that i didn't completely missed the point of the question :)
  • · Replies 19 ·
16K
  • · Replies 46 ·
