Register to reply
Calculating Tension in Cord in 2-Pulley System
by maximoanimo
Tags: 2pulley, cord, tension
Share this thread:
maximoanimo
#1
Sep13-10, 02:47 PM
P: 6
I attached a picture of the given figure to this thread. The suspended 2.5kg mass is moving up, the 2.9kg mass on the ramp is sliding down, and the 9kg mass is moving down. It is given that there is friction between the block on the ramp and the ramp itself with a coefficient of friction = 0.11. The pulleys are massless and frictionless.
What is the tension in the cord connected to the 9kg block?
2. Relevant equations
F = ma
3. The attempt at a solution
So, I drew three free-body diagrams for the three separate masses. I'll call the furthermost left mass m1, the middle block on the ramp m2, and the rightmost mass m3.
The forces acting on m1 are the force of gravity and the tension in the far left cord (I'll call this tension T1, and m1's overall acceleration a1). Therefore, since m1 is falling:
Sum(forces) = m1g - T1 = m1a1
For m2, in the x direction the forces are the force of friction in opposite direction to the motion, the tension in cord T1, the tension in the other cord T2, and the x-component of gravity, m1gsin(33). In the y direction, the forces are the normal force and the y-component of gravity. Therefore:
Sum(x forces) = T2 + Ffriction - T1 - m2gsin(33) = m2(a2 - a1)
Sum(y forces) = n - mgcos(33) = 0
The free-body diagram for m3 is the same as m1, but the object is moving in opposite direction so:
Sum(forces) = T2 - m3g = m3a2
I've reached this point and I believe my equations are right (except possibly the sum of x forces for m2), but I can't seem to figure how to combine these equations to determine T1.
Any help is greatly appreciated. Thanks!
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
Doc Al
#2
Sep13-10, 02:59 PM
Mentor
Doc Al's Avatar
P: 41,306
Quote Quote by maximoanimo View Post
(1) Since m2 is moving down the incline, why not choose that as your positive direction?
(2) Since the masses are connected by cords, how must their accelerations relate?
(3) How can you express Ffriction in terms of other quantities?
Your analysis of m1 and m3 is good.
maximoanimo
#3
Sep13-10, 07:24 PM
P: 6
(1) Yeah, that makes a lot more sense.
(2) I figured there was no related between the acceleration of the two cords since they were not on the same pulley. Are they equal but opposite (a1 = -a2)?
(3) I actually meant to fill that in. Following from friction force = u x n,
Ffriction = (0.11)m2gcos(33) = 2.6219
Therefore, using the equation for the x forces on m2:
T1 + m2gsin(33) - T2 - 2.6219 = 2(m2)(a)
T1 - T2 = 5.8a - 12.8567
Solving the equations for m1 and m3, we find:
T1 = 88.2 - 9a
T2 = 24.5 - 2.5a
T1 - T2 = 63.7 + 11.5a
Equating this equation with the previous:
11.5a + 63.7 = 5.8a - 12.8567
5.7a = 76.5567
a = 13.431
Plugging this into the equation for T1,
T1 = 88.2 - 9(13.431) = 32.679
But that answer is definitely wrong. I feel kinda lost, can someone give me some guidance on where I need to go with this problem? I been trying for a couple of days hahha.
Doc Al
#4
Sep14-10, 04:52 AM
Mentor
Doc Al's Avatar
P: 41,306
The three masses are connected, so they all have the same speed and the same magnitude of acceleration.
Redo this calculation.
Tip: Generally, it's a good idea to hold off from using the calculator as long as possible. Try to solve the equations symbolically until the last step. This way if you make an arithmetic mistake you won't have to redo everything.
maximoanimo
#5
Sep14-10, 11:09 AM
P: 6
Thanks a ton, Doc Al! I finally got the answer right lol.
Register to reply
Related Discussions
Pulley System and Tension Introductory Physics Homework 1
Tension in a pulley System Introductory Physics Homework 1
Tension in a pulley cord Introductory Physics Homework 6
Calculating Tension in a Two Pulley Atwood Machine Introductory Physics Homework 0
