Vector parameterization of intersection of 2 surfaces
The problem involves finding a vector parameterization of the intersection of two surfaces defined by the equations x² + y⁴ + 2z³ = 6 and x = y² in R³.
  • Exploratory, Assumption checking
  • Participants discuss different parameterizations by letting x or y equal a parameter t. There is confusion regarding the correct form of the second surface, with some participants questioning whether it is x = y² or x = y³.
Participants are exploring various approaches to parameterize the intersection, with some expressing uncertainty about their methods. One participant acknowledges a mistake in the surface definition, leading to a clarification of the correct equation.
There is a noted discrepancy in the surface definitions that affects the parameterization attempts. One participant indicates that knowing the answer does not aid in understanding the correct method.
musicmar
Find a vector parameterization of the intersection of the surfaces x2+y4+2z3=6 and x=y2 in R3.
I let x=t.
Then y3=t
I solved the first equation for z in terms of x
z = cube root ((t2+(t(cube rt(t)) - 6)/-2)
I know this is wrong because I checked the back of the book, but I'm not sure how to do it correctly.
Thank you!
musicmar said:
I let x=t.
Then y3=t
Is your 2nd surface [itex]x=y^2[/itex] or [itex]x=y^3[/itex]?
In either case, to avoid taking sqare roots and cube roots of stuff, try letting [itex]y=t[/itex] instead and solving for x.
x=y3, sorry.
So, when y=t, x=t3
and z= cube rt ((-1/2)(t6+t4-6))
This is still wrong. The answer is <t2,t,cube rt(3-t4)>
It doesn't help that I know the answer unless I know how to do it, though.
musicmar said:
x=y3, sorry.
So, when y=t, x=t3
Judging from the answer, it looks as though the 2nd surface is supposed to be [itex]x=y^2[/itex], so I'd double check the question if I were you.
thank you. you were right, it was x=y^2.
  • · Replies 21 ·
