Intel or AMD is easier to overclock and be reliable?
  • Thread starter Thread starter Saint
The discussion centers around the ease of overclocking and reliability of Intel versus AMD processors. Participants share personal experiences, technical insights, and resources related to overclocking, including safety concerns and performance comparisons. The scope includes theoretical aspects of overclocking, practical advice, and anecdotal evidence from users.
  • Some participants feel that AMD processors are easier to overclock, citing personal experiences of achieving higher overclocks without failure.
  • Others argue that Intel processors are safer to overclock, claiming they have better thermal management and do not burn up as easily as AMD processors.
  • A participant mentions that the Pentium 4 series is particularly good for overclocking, with claims of significant overclocking potential when using proper cooling methods.
  • Concerns are raised about the heat generated by AMD processors, with some stating that they can become unstable at high temperatures.
  • There is a discussion about the feasibility of overclocking notebook CPUs, with a consensus that it is generally not recommended due to design limitations.
  • Some participants provide links to resources and guides for overclocking, indicating a desire for clearer instructions.
  • Disagreements arise regarding the thermal output of AMD versus Intel processors, with conflicting claims about which brand generates more heat at lower overclocks.
  • Several participants share anecdotal evidence and personal benchmarks to support their claims about the performance of Intel and AMD processors during overclocking.
Participants do not reach a consensus on whether Intel or AMD is easier to overclock or more reliable. Multiple competing views remain, with some advocating for AMD's ease of overclocking and others defending Intel's safety and performance.
Participants reference various cooling methods and their effectiveness, but there is no agreement on the optimal approach for overclocking. The discussion also highlights the importance of motherboard selection for successful overclocking, with differing opinions on which brands are best.
Saint
Can anyone give me website where it has clear instructions to play overclocking? :smile:
Computer science news on Phys.org
Beginner guides are http://www.overclockers.com/topiclist/index04.asp#BEGINNER%20GUIDES .
Answering the question, id feel much safer overclocking an AMD, damn intel!
#1, if you want to really learn how to overclock, go here
In my personal experiences, Intel is safer to overclcok, due to the fact it doesn't burn up if it gets to hot.
I also have gotten my best overclcoks on Intels.
http://alexrushing.com/miscpictures/celeron2ghzat3ghz.jpg
http://alexrushing.com/miscpictures/34GHZSANDRA.jpg
I have done a lot more with Intel than my AMDs, which o/c fairly nice, but be warned, AMD will get hot and burn up if you are not careful..
Good Luck Saint! :smile:
Greg Bernhardt said:
Intel may be safer, but amd is just so easy to overclock
Best and highest overclocks were done on P4s.
got to have the right motherboard tho, never get an Intel motherboard, no o/c features, get ASUS, Epox, Abit, etc, good o/c reputation mobos.
can we overclock the CPU of notebook?
generally no, and I would not recommend it if you could, because notebooks come perfectly balanced, and a slight o/c may throw it off, and overheat.
This is not true, it is actually less safe to over an intel cpu. You can overclock an AMD more than an intel before it stuffs up. Which means an AMD is safer, as if you take them both to the maximum level of an Intel, well the intel is the least stable and more likely to overheat and die. Therefore the AMD is safer.
AMD give off a lot more heat than intel (currently), so I don't know where you get your information... Please post some references KaneOris!
Personally i do not agree with you Anttech its in my expirience that Intel give off more heat at a lower overclock. AMD will give off more heat eventually but the intels will die from less heat. BTW, where are your references?
The latest notebooks come with features to prevent overheating and conserve battery that actually do the oposite of overclocking. Such as reverting CPU to half speed when doing tasks that are less CPU intensive.
I wouldn't recommend overclocking a notebook, as already stated, they are balanced for heat of rejection based on their design settings and there is little leeway for change.
Anttech said:
Its common knowledge that AMD's get hotter than Intel procs...
It used to be true that AMD procs generated more heat. It isn't anymore (for the newer procs). Check out the table on http://www.tomshardware.com/cpu/20040601/socket_939-01.html page. Intel's fastest (and therefore hottest) dissipates upwards of 100W, while AMD's dissipates 89W. That's one of the drawbacks of going for higher clock speed.
Go back to overclocking school bro..
Intel by far can go higher in overclocks than AMD on comparable CPUs.
Intel will not burn up, oppose to AMD, that will or will be on the verge of burning up(a64s)..
I have been overclocking for a long time, and have done over 100 overclcoks of at least 15% and higher.
The only good overclcoking AMDs, are the Barton Mobiles(best stepping), that do upwards of 300-900MHz increases..
Intel on the other hand, the whole line of Northwoods can minimally do a 500MHz overclcok, and good stepping P4s can do up to 1.4GHz increases..
please don't come in here and tell everyone that AMD is the best overclcocker, I have 4 overclocked AMDs, and 4 overclcoked Intel, and the Intels are by far the safest and and easiest to overclock..
here is one of my better ones..
this celeron runs 40c full load
here is another
http://alexrushing.com/miscpictures/megaownage2.jpg
(notice that the 3.4GHz P4 is much higher in performance rating than even AMD's best, the FX53.
this P4 runs 56c full load
here is my 2400XP, stock at 2GHz, it is 2.28GHz now..
http://alexrushing.com/miscpictures/2400XPat228.jpg
runs 64c full load
everything is on high grade air cooling..
pentium 4's are really good for overclocking.
they are safe b/c they won't let themselves get too hot, instead they underclock themselves if they get too hot.
if you have a prescott, you can get up to 80 or 85 C before this happens
ive heard of pentium 4 2.4s being overclocked to 4ghz and up and still using a relatively normal heatsink/fan combo for cooling
nah, not at 4ghz, that is compressor range there for a 2.4ghz.
Heh, certainly not 4.0 ghz. You will need nitrogen cooling ( or soemthing along the same lines ) for that. I saw that on Tom's Hardware.
A 2.4 Ghz will be overcloked to about 3.2 with a good heatsink, good compound, and a relative boost in vCore.
Overclocking with nitrogen, etc.
dekoi said:
Heh, certainly not 4.0 ghz. You will need nitrogen cooling (or soemthing along the same lines) for that. I saw that on Tom's Hardware.
For a 2.4GHz rated CPU, yes, I agree you would probably need nitrogen for a 4GHz overclock, if it could be done at all. What Tom's Hardware demonstrated regarding nitrogen, however, was an overclock to 5GHz - albeit with a 3+GHz rated CPU. Tom's Hardware's earlier attempts to 4GHz, etc., were achieved with refrigerant compressors. 4GHz for 3+GHz rated CPUs is achieveable with water or compressor cooling, as evidenced by the reports of CPU reviewers on newegg.com.
you guys need to go back to overclocking school, a compressor will give you up to -52c, and nitrogen will give you -196, cost comparitivly and what can happen, the compressor is the way to go, and a 2.4 with good stepping can do 4GHz on a good compressor.
I prefer water cooling myself, and have had a 2.4GHz at 3.4GHz
AMD athlon 3800 is faster than P4 3.6GHz?
no
AMD compares the 3800 to a 3.8GHz P4 tho, but in most benches the P4 would win.
18K
