Register to reply
Pressure/GPM/Diameter Calculations
by ISX
Tags: calculations
Share this thread:
ISX
#1
Sep16-10, 05:42 PM
P: 116
I have been searching for a long time and can't figure this out. The formulas I find are way over my head.
Anyhow, I am trying to find how much flow would go through 2 different sized pipes. One is 3/8" ID and the other is 1/2" ID. The 3/8" uses 26psi and the 1/2" uses 17psi. All I want to know is the GPM each one will flow. I noticed there was a lot about constant of liquids so just use water. As for pressure drop stuff, there is a pump drawing in water and the pipes are on the other side and they have no end on them, so they are just shooting the water out like a hose with no end on it.
Thanks for any help I can get on this. Sorry if it is a dumb question.
Phys.Org News Partner Physics news on Phys.org
UCI team is first to capture motion of single molecule in real time
And so they beat on, flagella against the cantilever
Tandem microwave destroys hazmat, disinfects
Bob S
#2
Sep16-10, 06:00 PM
P: 4,663
Go to http://www.pipeflowcalculations.com/
Click on one of the online calculators on the left-hand side.
There are also other on-line calculators on the web.
Bob S
ISX
#3
Sep16-10, 06:43 PM
P: 116
Quote Quote by Bob S View Post
Bob S
I have gone through that one and many others and I just can't figure them out.
Bob S
#4
Sep16-10, 09:27 PM
P: 4,663
Quote Quote by ISX View Post
I used the calculator I recommended, and got the following numbers for the pressure drop per 100 ft of pipe:
1/2" pipe, 2.9 gpm, pressure drop=17 psi per 100' of pipe
3/8" pipe, 1.3 gpm, pressure drop=24 psi per 100' of pipe.
If you wold rather not use an online calculator, you can use the Hazen Williams formula at http://www.engineeringtoolbox.com/ha...ter-d_797.html
Bob S
ISX
#5
Sep16-10, 09:39 PM
P: 116
Ah that works. Think I halfway understand the principles now too. Thanks for the help!
Register to reply
Related Discussions
Pressure incr/decr with diameter Introductory Physics Homework 1
Gas pressure in variable diameter pipe Classical Physics 2
Find flow given: diameter, length, pressure Mechanical Engineering 15
Determine the speed at which the water leaves the hole Introductory Physics Homework 2
