Proving Triangle with 90° Angle: Length of Hypotenuse Segment
  • Thread starter Thread starter juef
    Geometry
The discussion revolves around proving a geometric property related to a triangle containing a 90° angle. The original poster seeks to establish that the length of the segment connecting the midpoint of the hypotenuse to the vertex of the right angle is half the length of the hypotenuse.
  • Participants explore various methods to prove the relationship, including the use of Stewart's theorem, congruent triangles, and properties of angles in a semicircle. Some question the necessity of proving the statement given the visual representation provided.
The discussion is active, with multiple approaches being suggested. Participants are engaging with the problem from different angles, and some guidance has been offered regarding potential methods to consider. There is no explicit consensus on a single approach yet.
There is a mention of varying levels of geometric knowledge among participants, which may influence the suggested methods and understanding of the problem.
juef
Hi all,
I'm having a hard time proving something. Let's say you have a triangle with a 90° angle. How can I prove that the length of the segment between the middle of the hypotenuse and the 90° angle is half the length of the hypotenuse itself?
Here's a little pic to help you...
Thanks a lot, and sorry for my pityful english! :)
john
Uh... isn't that what the picture says anyways? Why do you need to prove it if the picture is telling you it... or do you need to proce it for all cases?
Well, I have to prove that if one of the two (the 90° angle or the length that is half the length of the hypotenuse) is true, then the other is too.
juef said:
Hi all,
john
I do not know your level of knowledge in geometry,the simplest solution I see at first sight is to use Stewart's relation (knowing also that [tex]b^2+c^2=a^2[/tex] and that the hypothenuse is split into two equal segments a/2).
See http://mathworld.wolfram.com/StewartsTheorem.html
With the notations used there we have:
[PA3]*[A1A2]2+[PA2]*[A1A3]2=[PA1]2*[A2A3]+[PA2]*[PA3]*[A2A3]
I think Stewart's theorem is an overkill in this case.
At the middle point of the hypothenuse, draw a segment parallel to one of the other two sides, and look for congruent triangles.
Try completing the rectangle.
How about using the (converse of the) fact that the angle in a semicircle is always a right angle ?
<Not sure if you've done circles yet. If not, I defer to robphy's suggestion.>
Well depends on the knowledge level.After all Stewart's relation can be easily deduced by applying Pitagoras' generalized theorem two times,rearranging a bit the equations and taking also into account that cosX+cos[π-X]=0.
Thank you everybody for your help, every advice was very helpful. :D
