How Do Stacked Boxes Affect Normal Force Calculations?
  • Thread starter Thread starter physicsss
    Degree
The normal force calculations for stacked boxes involve understanding the forces acting on each box. The normal force exerted by the table on the 40.0 kg box is calculated as (10.0 kg + 40.0 kg) * 9.8 m/s², resulting in 490 N. Conversely, the normal force that the 40.0 kg box exerts on the 10.0 kg box is 10.0 kg * 9.8 m/s², equating to 98 N. This demonstrates that the normal force is directly related to the weight of the objects being supported, following the formula F = m * g.
  • Understanding of Newton's laws of motion
  • Basic knowledge of force calculations
  • Familiarity with the concept of normal force
  • Knowledge of gravitational acceleration (g = 9.8 m/s²)
  • Study the application of Newton's second law in static systems
  • Learn about the effects of friction on normal force calculations
  • Explore advanced topics in mechanics, such as equilibrium and net forces
  • Investigate real-world applications of normal force in engineering scenarios
Students in physics, educators teaching mechanics, and engineers involved in structural analysis will benefit from this discussion on normal force calculations in stacked box scenarios.
physicsss
A 10.0 kg box is placed on top of a 40.0 kg box, which rests on a table.
Determine the normal force that the table exerts on the 40.0 kg box.
Is it 10.0*9.8+40.0*9.8?
Determine the normal force that the 40.0 kg box exerts on the 10 kg box.
Is it 10*9.8?
Yes, you're right. The normal force is equal to the force exerted in the direction opposite to the normal force (in this case the box or boxes).
Yes, you are correct. The normal force that the table exerts on the 40.0 kg box would be the weight of both boxes combined, which is (10.0 kg + 40.0 kg) * 9.8 m/s^2 = 490 N. This is because the table must support the weight of both boxes stacked on top of it.
Similarly, the normal force that the 40.0 kg box exerts on the 10 kg box would be equal to the weight of the 10 kg box, which is 10.0 kg * 9.8 m/s^2 = 98 N. This is because the 40.0 kg box is resting on top of the 10 kg box, and therefore the 10 kg box is supporting the weight of the 40.0 kg box.
In both cases, the normal force is equal to the weight of the object being supported, as determined by the formula F = m * g, where F is the normal force, m is the mass of the object, and g is the acceleration due to gravity.
  • · Replies 18 ·
