Calculating Time of Excited Electron in Ground State
  • Context: Graduate
  • Thread starter Thread starter Darkmisc
    Electrons Excited
The discussion focuses on the calculation of the time an electron spends in an excited state before returning to its ground state. It highlights the relationship between the attractive force of the nucleus and the electron's transition between energy levels. The use of the energy-time uncertainty principle, represented by the equation ΔEΔt ≥ ℏ, is emphasized as a method to calculate this time. Additionally, the formula E = (π²ℏ²n²)/(2mL²) is presented for determining the energy levels and corresponding time spent in excited states.
  • Understanding of quantum mechanics principles, specifically energy levels and electron transitions.
  • Familiarity with Planck's constant and its implications in quantum physics.
  • Basic knowledge of classical mechanics and its application to quantum systems.
  • Concept of the energy-time uncertainty principle in quantum mechanics.
  • Study the implications of the energy-time uncertainty principle in quantum mechanics.
  • Explore the derivation and applications of the formula E = (π²ℏ²n²)/(2mL²).
  • Investigate the behavior of electrons in heavy elements and their excited state lifetimes.
  • Learn about quantum leap phenomena and their mathematical modeling.
Physicists, quantum mechanics students, and researchers interested in electron behavior and energy transitions in atomic structures.
Darkmisc
What determines the amount of time that an electron spends in an excited state before it drops back to its ground state?
Is the attraction between the electron and the nucleus the cause? Would the electrons in heavy elements spend less time in their excited states?
I'm conceptualising an excited electron as similar to a ball thrown in the air (that must fall back to earth).
If we:
1. (erroneously) assume that an electron can travel in the space bewteen energy levels; and
2. apply classical mechanics to predict how long the electron should take to reach its peak before falling to its ground state (due to attractive force of nucleus),
would that time be the same as the time it takes for the electron to make a quantum leap to its excited state and then back to its ground state?
Thanks
well delta E, delta t(time) >_ Plancks constant
there you can calculate the time if you know the energy where
E= (pi)^2 (plancks)^2 (n)^2/(2mL^2)
where n is the energy level and L is the diameter of an electron.
There you can calcuate the time it will spend on the energy state.
  • · Replies 18 ·
  • · Replies 19 ·
