Help Needed: Increasing Water Heating Rate w/ 300W Element
The discussion revolves around a scenario involving a heating element and a bag of water, specifically focusing on how to increase the rate at which the water is heated. The problem is situated within the context of thermodynamics and electrical principles, particularly concerning a 300W heating element.
  • Mixed
  • Participants explore various methods to increase the heating rate, including reducing resistance and altering the amount of water. Questions are raised about heat loss, insulation properties of the floor, and the nature of the current (AC vs. DC).
The discussion is active, with participants offering different perspectives and questioning assumptions. Some guidance has been provided regarding the nature of the current and the insulation of the floor, but no consensus has been reached on the best approach to take.
Assumptions include that the current and voltage supplied to the heating element remain unchanged, and there is an assumption of no heat loss from the water. The discussion also touches on the implications of using AC current.
le_arjun
Hi ,
I have a question that's confusing and difficult to comprehend
" A heating element is placed on the floor and bag of water is placed over it. At present, A power of 300W is applied to the heating element. Peter, the technician, wants to increase the rate at which the water in the water bag is heated up. What should peter do to increase the rate?"
assuming the current supplied and the voltage across the heating element are not changed, reducing the resistance would do the trick. but reducing the resistance can be done only by changing the heating element . kind of confused...
Can someone help?
Questions...
Is heat loss of the water considered?
Is the floor a perfect insulator?
Is this a electronics problem, or thermodynamics? (usually the answer should be in a specific domain for a vaguely given problem.)
Is the current DC or AC? ( Very important to know).
its an AC current, floor- perfectly insulated, and assuming there is no heat loss from water...
you can reduce the amount of water...
If AC current what other variables are there that Peter can play with, and what is their effect.
I said"you can reduce the amount of water" ...I AM SERIOUS
Don't be.
This is a AC phys problem so all other ways... like breathing hot air onto it, or hitting it with a bat to hopefully create life that is able to evolve cold fusion is not an option.
  • · Replies 28 ·
9K
