General equation for press/shrink fit stress?
by cowpuppy
Tags: equation, press or shrink, stress
cowpuppy
cowpuppy is offline
#1
Sep23-10, 04:30 AM
P: 9
I'm trying to figure out what shear stresses there would be from a shrink fit assembly, if any. You have a cylindrical solid shaft and a cylindrical hub, where the shaft diameter is greater than the hub's hole diameter. The shaft cooled and thus shrunk and the hub is heated and expanded so they will fit together, then allowed to come back to the original temperature.
Will either the shaft or cylindrical hub experience any shear stresses?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
minger
minger is offline
#2
Sep24-10, 06:13 AM
Sci Advisor
P: 1,498
Basically you can use superposition to find this. There is an interference, call it e. You can find the pressure which would cause that expansion e. The stress in the shaft from the interference will then be the stress caused from that pressure.
It should be all hoop stress if I'm not mistaken. Looked it up, from Roark, you have the radial displacement
[tex]
\Delta R = \frac{qR^2}{Et}
[/tex]
The idea is then to find q that causes your interference R. Then your meridional stress is zero, while your hoop stress is
[tex]
\sigma_2 = \frac{qR}{t}
[/tex]
Good luck,
Register to reply
Related Discussions
Stress/strain+general bending equation.... Introductory Physics Homework 3
Understanding a stress equation Mechanical Engineering 4
Shear Stress Differential Equation Calculus & Beyond Homework 1
stress-strain relation and constitutive equation Advanced Physics Homework 16
Stress @ Proportional Limit, Ultimate Stress, Breaking Stress, etc. General Physics 0
