New Reply
Concentric circles are parallel?
Share Thread Thread Tools
Oct19-10, 07:54 AM   #205
Quote by CRGreathouse View Post
That didn't answer the question. Even this many pages into the thread, you still haven't told us what you mean by parallel (what the rest of us call phya-parallel).
I'm done with this thread. If someone is able to formalize a definition for phya-parallel, feel free to message me and I'll check back to see what it is. Until then, have fun!
If a line (straight line either curve) to another line (straight line or curve) the distance maintains invariable, then these two lines (straight line or curve) are parallel.
Oct19-10, 09:43 AM   #206
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by phya View Post
I suspected that you did not know what a mathematical definition was. What you are giving, over and over again, are "characterizations" or "examples', not definitions. You seem to be saying that two "lines" (which, in your definition can be curves) are parallel if and only if they "maintain" a constant distance. But for that to be a complete definition, You must tell exactly how you are defining the "distance" between two curves- and there are a number of quite different ways of doing that. And, as I said before, depending on exactly how you define that distance, you might find that there are examples of curves that are "parallel" in your definition but also intersect!
Oct19-10, 10:02 AM   #207
Quote by HallsofIvy View Post
Please give an example!
Oct19-10, 04:40 PM   #208
Recognitions:
A "conchoid" is a curve that loops back on itself. Another conchoid, just slightly distant from the first, where the "distance" is defined along a mutual perpendicular, will have constant distance yet intersects- the points of intersection on the curves not having a mutual perpendicular so that, even though the curves intersect, the "distance" between them is not 0. As I said, you have to be careful how you define the "distance" between two curves.
Oct20-10, 07:39 AM   #209
You said right, on the exploration path, we must be careful. In the plane, between two curve's distances to be vertical to two curve line segment length.
Oct20-10, 07:41 AM   #210
The attention, is must simultaneously be vertical to two curves.
Oct24-10, 07:39 PM   #211
To add concentric circles to our definition of "parallel lines," you would have to prove all the rules for parallel lines apply. One of those rules has to do with parallel lines intersecting other parallel lines (corresponding angles are equal). Can you show me even one that works? (ALL should work if what you say should be accepted.)
Oct25-10, 10:15 AM   #212
Quote by AC130Nav View Post
The straight line parallel has the phase angle to be equal, generally, the curve parallel does not have the corresponding angle to be equal.
New Reply
Tags
curve, parallel
Thread Tools
Similar Threads for: Concentric circles are parallel?
Thread Forum Replies
Potential Difference between Concentric Circles Introductory Physics Homework 1
concentric circles with radii, outside and inside areas General Math 0
Concentric Circles & Magnetic fields Introductory Physics Homework 2
Double Integral of two concentric circles Calculus & Beyond Homework 8
