Comet Passing by Earth: Effects & Destruction
  • Context: High School
  • Thread starter Thread starter mersecske
    Comet Earth
The discussion revolves around the potential effects of a comet passing by Earth, including scenarios of near misses, collisions with the Moon, and the implications of small perturbations. Participants explore theoretical and speculative aspects of these events, considering both destructive and measurable effects.
  • Theoretical speculation
  • Some participants propose that a comet could cause destruction without collision, depending on its size and proximity, suggesting that close encounters could lead to tidal forces causing earthquakes.
  • Others argue that a typical comet's mass is negligible compared to the Moon, indicating that a near miss would have no measurable effect on Earth.
  • A participant mentions that debris from a collision with the Moon could have disastrous consequences for Earth, but emphasizes that the comet would need to be large for significant effects.
  • There is a discussion about the potential for small perturbations to affect the length of a day, with some suggesting that any changes would be minimal due to Earth's large angular momentum.
  • One participant references the Tunguska event as an example of a destructive airburst caused by a meteor, emphasizing that such events can occur without direct impact.
  • Several participants express disinterest in discussing meteors entering the atmosphere, focusing instead on the implications of comets passing outside it.
  • Theoretical questions are raised about the effects of a very large comet, with some participants suggesting that the size and proximity of such an object would determine its potential impact.
Participants generally do not reach a consensus, with multiple competing views on the potential effects of comets passing by Earth, including differing opinions on the significance of size and distance.
Limitations include assumptions about the size and mass of comets, the nature of their cores, and the conditions under which they might affect Earth. The discussion remains speculative and theoretical without definitive conclusions.
mersecske
A huge meteor can cause to destroy the civilization.
But let assume that a comet pass by the Earth.
Can a comet cause such a big destruction without collision?
2)
Let assume that a comet collide with the Moon.
This situation can cause such a big destruction on the Earth?
3)
And in the case of just small perturbation,
what kind of effects can be detected?
For example the length of he day can change?
Astronomy news on Phys.org
A typical comet might mass something like 1e15 kg. This is in the order of 1/100,000,000 the mass of the Moon. A near miss would have no measurable effect on the Earth.
A direct collision with the Moon would have less of an effect on the Moon's orbit than the variation it already exhibits due to its eccentricity, so again, the effects on Earth would be nil.
mersecske said:
1)
Depends on how big and how close. Close enough and tidal forces would cause earthquakes, but too close and the comet would break up, with unpredictable consequences. Smaller comets also leave a trail of debris behind them which can cause a meteor storm, though the meteors typically look spectacular without any effect on the ground.
2)Let assume that a comet collide with the Moon.
Debris from the collision can either fall or collide with the Earth, with disastrous consequences, but the comet needs to be large.
3)And in the case of just small perturbation,what kind of effects can be detected?
That's very unlikely as the angular momentum of the Earth is very large. Any perturbations will be very small, though probably measurable. If the 'comet' is hundreds of kilometers across - a dwarf planet - then its tidal interaction could cause perturbations of several minutes in a day.
mersecske said:
1)
It is my firm belief that the Tunguska event resulted because of an airburst of a meteor in the lower atmosphere of the earth.
A 10 meter meteor can cause an airburst comparable to the fatman nuclear device dropped on japan.
With the Tunguska event, the blast was directed downward at first and then traveled along the ground in an outward radius. The blast radius was 8 kilometers wide and scorched and laid flat trees. Windows were shattered in villages more than 200 miles from the blast.
The meteor completely burned up in the atmosphere. So it never impacted the Earth. But, it was extremely destructive, nonetheless, and would have been a horrific tragedy of historic proportions if the blast had occurred over a populated area.
I don't want to talk about meteors entering into the atmosphere.
It happens many times every day.
What do you want to talk about? The question was pretty vagur.
If you are talking specifically about a comet, and you mean that it passes by the Earth but does not enter the atmosphere, then I don't know why you need an answer from us. Why would a comet traveling outside our atmosphere have any impact on humanity other than that it could possibly impact with a satellite?
Many comets have solid cores of rock in their nucleus. Others are a mixture of rock and ice. Smaller comets with non-solid rock interiors would almost certainly burn up in the upper atmosphere. A larger comet with a solid rock core could produce the same explosion as a similarly sized meteor.
Janus' post #2 anwers any questions about near misses by comets.
My question is theoretical for example a very big comet (bigger than real ones)
without entering the atmosphere can cause such effects.?
Ah. Fiction. Well, all bets are off then, aren't they?
How big do you want this planetesimal to be? You'll have to start looking at some of the larger asteroids. Ceres is still 1/100th the mass of the Moon.
How close would you like it to come? Graze the atmo?
  • · Replies 28 ·
  • · Replies 33 ·
