| Thread Closed |
Objects passing from air to water without leaking |
Share Thread | Thread Tools |
| Sep26-10, 05:58 AM | #1 |
Is there a system (e.g. valve) which enables objects (e.g. ball) passing from air to water containers without leaking?
I imagine this is near to impossible since water is nearly 1,000 times denser than air... To make it work air would have to be compressed so air density in air container is close to that of water density in water container? I wonder how those openings in submarines work (serving divers to go in/out of water at depths) where water doesn't fill the submarine? (I doubt air pressure in submarine is equal to water pressure there at great depths, or is it?) |
| Sep26-10, 07:06 AM | #2 |
| Sep26-10, 07:53 AM | #3 |
I see my question is not clear enough.
I'm asking about a way for object to pass into water from air through vertical 'wall' (say via valve in middle of that wall)... |
| Sep26-10, 03:05 PM | #4 |
An airlock?
http://en.wikipedia.org/wiki/Airlock |
| Sep26-10, 05:10 PM | #5 |
Airlock: 'The air pressure of the airlock—the space between the doors—is equalized with that of the environment beyond the next door to open.' Is there a simpler way to make small objects pass from air to water (without the need for adapting pressure)? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Objects passing from air to water without leaking
| Rate water has to be added to Leaking cone | Calculus & Beyond Homework | 4 | ||
| leaking water problem | Calculus & Beyond Homework | 5 | ||
| Water leaking from a tank | Calculus & Beyond Homework | 3 | ||
| water leaking out of plastic? | General Physics | 5 | ||
