Register to reply
Tension problem
by hm8
Tags: tension
Share this thread:
hm8
#1
Sep26-10, 01:37 PM
P: 16
The distance between two telephone poles is 46.0 m. When a 1.50 kg bird lands on the telephone wire midway between the poles, the wire sags 0.190 m.
How much tension does the bird produce in the wire? Ignore the weight of the wire.
2. Relevant equations
F=ma
3. The attempt at a solution
I really just don't know where to start with this one...its confusing to me since the force of the bird (1.5 kg*9.8m/s2 = 14.7 N) is vertical, but the tension is sideways...so for F=ma, would I be looking at the sum of the forces in the x or y direction? Or is there some way to simplify it to one dimension?
Phys.Org News Partner Science news on Phys.org
Scientists discover RNA modifications in some unexpected places
Scientists discover tropical tree microbiome in Panama
'Squid skin' metamaterials project yields vivid color display
PhanthomJay
#2
Sep26-10, 01:48 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,049
What's the question?
JaredJames
#3
Sep26-10, 01:49 PM
P: 3,387
So the question is find the tension in the cable?
cepheid
#4
Sep26-10, 01:51 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,196
Tension problem
The tension is not entirely horizontal, because the rope sags. You'll have to resolve the forces into components. In reality, the rope would probably curve, but for simplicity, why don't you assume that the rope has two straight, sloping sections that meet at the midpoint (where the bird is sitting), to form a sort of "V" shape. The vertical position of the midpoint (bottom of the "V") is 0.190 m below where it was when the bird was absent and the rope was horizontal.
Does that help?
hm8
#5
Sep26-10, 01:52 PM
P: 16
Gah, somehow forgot to put the question in. Sorry.
Dadface
#6
Sep26-10, 01:52 PM
PF Gold
Dadface's Avatar
P: 2,031
Hello hm8.If by sideways you mean horizontal that's not exactly true.The wire sags so the wire on each side of the bird is inclined upwards at an angle to the horizontal.Start by sketching a diagram and marking in the forces at the point where the bird is.You will have the weight of the bird acting down and the tension in each side of the wire acting along the line of the wire.
hm8
#7
Sep26-10, 02:01 PM
P: 16
Quote Quote by cepheid View Post
Does that help?
Okay...so the downward component of the tension force is 14.7 N?
Still not sure where to go from there...how do I use the length of the wire and the amount it sags? I guess I can figure out that the length of one half of this 'V' is 23.0007 m (square root of .192 + (46/2)2), but does that help me?
cepheid
#8
Sep26-10, 02:05 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,196
Quote Quote by hm8 View Post
No, because tension always acts in the "along the length of the rope" direction. Dadface has given you good advice when it comes to actually implementing what I suggested.
Edit: okay maybe it's not so clear from his post as I thought. Use what you know of the geometry of the situation to figure out by what angle each half of the rope is inclined (relative to the horizontal). Then use that angle, and basic trigonometry, to resolve the tension force into horizontal and vertical components. Then use Newton's second law to figure out what conditions on those components must be true in order for the situation to be static (i.e. sums of forces in x and y directions are *each* equal to zero) .
hm8
#9
Sep26-10, 02:24 PM
P: 16
Okay, so the rope is inclined at and angle of 0.00826 degrees above the horizontal.
So the components of the tension vector would just be Cos(0.008)T and Sin(0.008)T
So, in the Y direction...
F = ma
-mg + Sin(0.008)T = 0
-14.7 N + Sin(0.008)T = 0
T= 14.7 N/Sin(0.008)
...is that right so far? Or does the force of gravity on the bird not fit in there?
EDIT:
Sorry, make that .4733 degrees for the angle, my calculator was in radians mode.
cepheid
#10
Sep26-10, 03:23 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,196
The method looks right with a few minor issues. Draw a free body diagram for the bird. What forces act on it? In particular, how many forces act on it due to the rope? What I'm hinting at is, are you sure that there should be only one Tsin(theta) term?
Register to reply
Related Discussions
Tension Problem Introductory Physics Homework 4
Another tension problem Introductory Physics Homework 3
Tension problem Introductory Physics Homework 5
Tension HW problem. Introductory Physics Homework 4
Tension Problem Introductory Physics Homework 2
