| Thread Closed |
modelling a vacuum pipe using an orthogonal material |
Share Thread | Thread Tools |
| Sep27-10, 03:14 AM | #1 |
Hi!
I'm trying to model a vacuum pipe on Ansys. I've already modelled it using an isotropic material, assuming its a plane strain problem (infinate pipe), but now I want to use a laminate structure composed of an orthogonal material such as nomex (honeycomb) with a seal tight layer of Al or Beryllium glued to the inside surface. I'm firstly struggling to find any of the required data i.e. x,y,z moduli etc. Also, does anyone know of any good method of simplifying a model such as this, for instance by averaging the properties and using an isotropic model...if that doesn't sound stupid... Thanks for any ideas or sources of information! |
| Thread Closed |
| Tags |
| ansys, fea, pipe, pressure vessel |
| Thread Tools | |
Similar Threads for: modelling a vacuum pipe using an orthogonal material
| Vacuum Pump in a Pipe System | Mechanical Engineering | 0 | ||
| Vacuum Delivery Pipe System for a Double-storey Office | Mechanical Engineering | 0 | ||
| Orthogonal matrices prove: T is orthogonal iff [T]_bb is an orthogonal matrix | Calculus & Beyond Homework | 0 | ||
| Pipeline pump station pipe burst modelling | Mechanical Engineering | 2 | ||
| Modelling a vacuum tube? | Engineering Systems & Design | 13 | ||
