Thread Closed
Current Limitation in a PN junction
Share Thread Thread Tools
Sep27-10, 10:15 PM   #1
Describe the limiting physical mechanism for current flow in a p-n junction where there is negligible recombination in the space charge region. Write the equations that describe this current flow process. Define all parameters.
a) for the general case where the junction is forward biased.
b) under reverse bias.
c) describe the total current in (a) and (b) if there is recombination in the space charge region.
2. Relevant equations
3. The attempt at a solution
The expression with the defined reverse saturation current comes from the diffusion current densities at the depletion region endpoints, and the recombination will account for a term that depends on the lifetime of going through the depletion region:
Diffusion current is dominant in front bias and current is 'limited' by diffusion of minority carriers, and drift current is dominant in reverse bias and apparently is also 'limited' by the majority carriers.
I'm not sure what is meant by 'limiting' here?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Thread Closed
Tags
pn junction current
Thread Tools
Similar Threads for: Current Limitation in a PN junction
Thread Forum Replies
current limitation through multijunction solar cell Atomic, Solid State, Comp. Physics 1
Current in p-n junction Atomic, Solid State, Comp. Physics 0
Finding reverse sat current of pn junction diode Engineering, Comp Sci, & Technology Homework 2
PN Junction Question - Current Atomic, Solid State, Comp. Physics 2
WHY is drift current through a PN junction independent of applied bias voltages? Atomic, Solid State, Comp. Physics 2
