| Thread Closed |
Exploiting Geometric Series with Power Series for Taylors Series |
Share Thread | Thread Tools |
| Sep28-10, 08:54 PM | #1 |
I'm confused between some formulae so I'm going to give some examples and you can let me know if what I'm writing is correct.
Find the Taylor series for.... EXAMPLE 1: [tex]f(x) = \frac{1}{1- (x)}[/tex] around [tex]x = 2[/tex] Then, [tex] \frac{1}{1-(x)} = \frac{1}{3-(x+2)} = \frac{1}{3} \left( \frac{1}{1 - \frac{(x+2)}{3}} \right) = \frac{1}{3} \sum_{n=0}^{\infty} (\frac{x+2}{3})^{n} = \sum_{n=0}^{\infty} \frac{(x+2)^{n}}{3^{n+1}}[/tex] provided that [tex]| \frac{x+2}{3} | < 1[/tex] or, [tex] -5 < x < 1[/tex] Does this look correct? Now if I do the same question in another fashion... [tex]\frac{1}{1-x} = \frac{1}{1 + (-x)} = \frac{1}{3 + (-x -2)} = \frac{1}{3} \left( \frac{1}{1 + (\frac{-x-2}{3})} \right) = \frac{1}{3} \sum_{n=0}^{\infty} (\frac{-x-2}{3})^{n} = \frac{1}{3} \sum_{n=0}^{\infty} (-1)^{n} \frac{(x+2)^{n}}{3^{n}} = \sum_{n=0}^{\infty} (-1)^{n} \frac{(x+2)^{n}}{3^{n+1}} [/tex] provided that [tex]| \frac{(-x - 2)}{3} | < 1[/tex] or, [tex] -5 < x < 1[/tex] They aren't equal, in this one I have a [tex](-1)^{n}[/tex] kicking around in my sum. What am I doing wrong here? |
| Sep28-10, 09:12 PM | #2 |
So is the first one correct, and the 2nd one incorrect?
EDIT: The post above this one was removed. |
| Sep28-10, 09:14 PM | #3 |
In the second series, you're expanding
[tex]\frac{1}{1+x} = 1-x+x^2-x^3+\cdots[/tex] You forgot the alternating sign, which cancels with the factor of [itex](-1)^n[/tex]. |
| Sep28-10, 09:19 PM | #4 |
Exploiting Geometric Series with Power Series for Taylors Series[tex]\frac{1}{1+x}[/tex], I can never see it in my work. So is the 2nd one incorrect then, or correct and I'm just not understanding why? |
| Sep28-10, 09:22 PM | #5 |
A series expansion around [tex]x=2[/tex] is an expansion in [tex]x-2[/tex]. Also, for the 2nd derivation, you'll find that the expansion of [tex]1/(1+u)[/tex] has a factor of [tex](-1)^n[/tex] that cancels out the one that you introduced.
| Sep28-10, 09:27 PM | #6 |
I'm not doing, [tex]1/(1+x)[/tex] I'm doing [tex]1/(1-x)[/tex] I'm sure you know this, and it is probably me who's misunderstanding something but I still can't see it. Is it just that the [tex](-1)^{n}[/tex] I introduced gets canceled, and that's it? |
| Sep28-10, 09:34 PM | #7 |
The 1/(1+u) appears in the 3rd part of the 2nd derivation:
| Sep28-10, 09:34 PM | #8 |
When you do the expansion, you'd expanding a function of the form 1/(1+u), not 1/(1-u), where u=-(x+2)/3.
| Sep28-10, 09:46 PM | #9 |
[tex]\frac{1}{3} \left( \frac{1}{1 + (\frac{-x-2}{3})} \right) = \frac{1}{3} \sum_{n=0}^{\infty} (-1)^{n} (\frac{-x-2}{3})^{n}[/tex] That would take care of the "+ sign", right? But then when I pull the other, [tex](-1)^{n}[/tex] out I'll get, [tex](1)^{n}[/tex] and my problems will be fixed, correct? |
| Sep28-10, 09:59 PM | #10 |
Yes, both expressions agree. Are you meant to expand around x=2 or x=-2? Your OP says x=2, but your expansions are around x=-2. You have the proper radii of convergence, so I'm not sure if the first line of your example is a typo or not. |
| Sep28-10, 10:02 PM | #11 |
I guess if I'm doing, [tex]\frac{1}{1 - x}[/tex] then I sub in, [tex] x + 2[/tex] or [tex] x - 2[/tex]? Similarly, if I'm doing, [tex]\frac{1}{1 + (-x)}[/tex] then I sub in, [tex] x + 2[/tex] or [tex] x - 2[/tex]? This should be the last bit of confusion I have to clear up! |
| Sep28-10, 10:07 PM | #12 |
[tex]\frac{1}{1\pm a(x-2)}[/tex]. The important thing is that x=2 is actually within the radius of convergence of your expansion. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Exploiting Geometric Series with Power Series for Taylors Series
| Geometric series. Find the sum of the series. Powers. | Precalculus Mathematics Homework | 2 | ||
| Geometric Sum (Power Series) Calculation | Calculus | 5 | ||
| Geometric power series | Calculus & Beyond Homework | 1 | ||
| Geometric power series | Calculus & Beyond Homework | 2 | ||
