Shortest time from a point to a moving point
  • Context: Graduate
  • Thread starter Thread starter yang
    Point Time
The discussion revolves around determining the shortest time for a point A, moving at a constant velocity, to reach a point B that revolves around a circle. The problem involves mathematical modeling of the motion of both points, considering their velocities and positions over time.
  • One participant presents equations relating the distance between points A and B over time, noting the challenge in isolating time (t) from the equations.
  • Another participant questions what variables could be adjusted to yield different arrival times for A to reach B.
  • A different approach is suggested, defining the position of B in terms of angular speed and relating it to the position of A, leading to a system of equations to solve for time (t) and angle (θ).
  • Concerns are raised about the feasibility of obtaining a closed-form solution for t, with one participant suggesting that the minimum time occurs along a straight line.
  • Another participant highlights the possibility of varying the initial position of A, but points out that placing A at B's initial position results in an immediate arrival time.
  • Further discussion includes the complexity of relating θ to time and the challenges of having t both inside and outside trigonometric functions in the equations.
  • One participant references a related problem from an external source, suggesting a connection to a known challenge in mathematical problem-solving.
Participants express differing views on the variables that can be adjusted to find the shortest time, with no consensus on a single approach or solution method. The discussion remains unresolved regarding the best method to determine the shortest time.
Participants note limitations in their approaches, including the difficulty of isolating time in the equations and the dependence on initial conditions. The complexity of the problem is acknowledged, with various assumptions about the motion of points A and B being discussed.
yang
Lets say you have 2 points A and B. A is given as (x, y) and B is a point that revolves on a circle. You are given the radius (r), the initial angle (i), and the velocity that it travels at (v_b). You are also given the velocity that A travels at (v_a). The center of the circle is (0,0) and all points relate it that point.
http://img90.exs.cx/img90/8300/pic32.jpg
You want to find the shortest amount of time it takes for A to reach B.
To do it in the shortest amound of time, A must travel in a straight line. In order to do that, you must know where B will be in the same amount of time it takes A to get there.
I've created 2 equations for distance that relate to time.
d(t) = sqrt( (x - rcos(at + i))^2 + (y - rsin(at + i))^2 )
d(t) = (v_a)t
These combine to make
(v_a)t = sqrt( (x - rcos(at + i))^2 + (y - rsin(at + i))^2 )
*note: sqrt = square root
d = distance (variable)
t = time (variable)
x = x-coordinate of A (constant)
y = y-coordinate of A (constant)
r = radius (distance from (0,0) to B) (constant)
i = initial angle (constant)
v_a = velocity of A (constant)
v_b = velocity of B (constant)
a = angular velocity (v_b / r) (constant)
The thing that is wrong with this equation is that you cannot isolate t, but you can use it to approximate t.
I've tried finding d'(t) and (d^2)''(t) to eliminate t from one of the functions (I'm not sure they are functions).
d'(t) = ( axrsin(at + i) - ayrcos(at + i) ) / sqrt( (x - rcos(at + i))^2 + (y - rsin(at + i))^2 )
d'(t) = v_a
(d^2)''(t) = 2(a^2)xrcos(at + i) + 2(a^2)yrsin(at + i)
(d^2)''(t) = 2(v_a)^2
But, these functions don't help in finding t.
The main purpose is to find the shorest amount of time it takes for A to get to B.
So, there's got to be another method, right?
Exactly what is varying that would allow you to get different "arrival times?"
Let (x0,y0) be the initial point of A. I will assume, from your picture, that B's initial point is (0, r). Let ω be the angular speed of B in radians per sec (if your vB is in linear units per second, then ω= vB/r). The position of B at any time t is (r cos(ωt), rsin(ωt)).
Assume that A moves in a straight line making angle θ with the x-axis at (linear) speed vA. Then the position of A at any time t is (x0+ vAcos(θ)t, y0+ vAsin(θ)t) (Notice that the t is NOT in the trig function here! cos(θ) and sin(θ) are constants!).
When "A reaches B" these two points must be the same for the same t. That gives two equations: r cos(ωt)= x0+ vAcos(θ)t and rsin(ωt)= y0+ vAsin(θ)t to solve for the two "unknowns", t and θ.
I suspect you won't be able any "closed formula" solution for t.
(I suppose you put this in the "calculus" section because of the "minimum time" requirement but once you recognize that the minimum time, with constant speed, is on a straight line, you don't need calculus.)
(Tide: to answer your question, I am assuming that it is the initial position of A, (x0,y0), that is varying.)
Halls,
I thought of varying the initial position too but then the obvious answer is to simply place A at the initial position of B, i.e. tmin = 0!
Well, yes, but I assumed the problem was: determine the shortest time to go from A at (x,y) to B as a function of (x,y).
Oh. That's another approach i didn't think of. I think you forgot to put the intial angle in the sin and cos functions for B. This method sets θ in relation to t, instead of distance in relation to t. This just as bad as my 2 equations for d(t) because you have t outside and t inside sin and cos functions. And how would you find θ?
Also, θ is in terms of t. So what would θ equal if written in terms of t?
This problem is what i think is the core of the "Cosmic Milkman" problem from Code Wars.
http://www.hpcodewars.org/PastEvents/CodeWarsV/Problems/Milkman.htm
You can read that if you want to understand the entire problem.
I have a thread in another website, too.
http://www.sosmath.com/CBB/viewtopic.php?t=9662
  • · Replies 18 ·
