Register to reply
Redox Reaction of Ascorbic Acid using IO3
by DavetheMD
Tags: acid, ascorbic, reaction, redox
Share this thread:
DavetheMD
#1
Sep29-10, 03:45 PM
P: 3
Equation 1 - IO3- (aq) + 6 H+ (aq) + 5 I- (aq) -> 3 I2 (aq) + 3 H20
The iodine formed will react with the ascorbic acid.
Equation 2 - C6H8O6 + I 2 -> C6H6O6 + 2 I- (aq) + 2 H+ (aq)
The goal is to determine the ascorbic acid concentration (mg/mL) in a Vitamin C solution. A 10mL sample Vitamin C solution was pipetted into an Erlenmeyer flask, to which water, .5 g KL(s), 5 mL of 1M HCl solution, and 1 mL 1% starch solution was mixed thoroughly.
Titration began with .0137M KIO3.
To reach the endpoint indicated by the blue color of the idoine-starch complex, required 18.96 mL IO3- solution.
2. Relevant equations
a. calculate the number of moles IO3- required for titration.
b. Calculate the number of moles of I2 (as I3-) produced in the reaction mixture.
c. Calculate the number of moles of ascorbic acid (176.14 g/mole) present in the 10-mL alquot. Calculate the molarity (M) of the ascorbic acid solution.
d. Calculate the mg/mL of ascorbic acid in the solution.
3. The attempt at a solution
a. I am assuming the easiest way to find the number of moles I03- required for titration is to take the 18.96 mL, convert it to L and multiply it by Molarity. But the Molarity I have known is for KIO3 (.0137M)
I didn't want to run this calculation without further clarification as to whether or not this is correct. Thanks!
Phys.Org News Partner Science news on Phys.org
Security CTO to detail Android Fake ID flaw at Black Hat
Huge waves measured for first time in Arctic Ocean
Mysterious molecules in space
Borek
#2
Sep29-10, 04:33 PM
Admin
Borek's Avatar
P: 23,392
If I understand you correctly you are not sure if the concentration of IO3- is identical to the concentration of KIO3?
DavetheMD
#3
Sep29-10, 04:40 PM
P: 3
Quote Quote by Borek View Post
www.titrations.info, www.chemistry-quizzes.info, www.ph-meter.info
Yes. I am not sure if "a. calculate the number of moles IO3- required for titration."
Is going to be (18.96 mL IO3- Solution) * (.0137M KIO3 required for titration)
Borek
#4
Sep29-10, 04:42 PM
Admin
Borek's Avatar
P: 23,392
Do you know how KIO3 dissociates?
DavetheMD
#5
Sep29-10, 07:51 PM
P: 3
Sadly. No. My text book is slightly cryptic.
My assumption is that K+ dissociates with the IO3-
Borek
#6
Sep30-10, 02:01 AM
Admin
Borek's Avatar
P: 23,392
I guess your book doesn't state anything as it assumes you to know that after earlier examples of different salts - most of them behave exactly the same way, listing each one separately doesn't make sense.
KIO3 -> K+ + IO3-
Now, if thats how the salt dissociate, and you are given concentration of KIO3, does it differ from teh concentration of IO3-?
Register to reply
Related Discussions
Redox reaction Biology, Chemistry & Other Homework 3
Acid-Base Reaction with Acetic Acid and Ammonia Biology, Chemistry & Other Homework 1
Chemical Reactions - Redox and Acid/Base Biology, Chemistry & Other Homework 0
Redox Reaction Biology, Chemistry & Other Homework 1
Activation energy for oxidation of ascorbic acid. Biology, Chemistry & Other Homework 0
