Atmosphere can be absorbed into the solution?
  • Thread starter Thread starter .....
    Atmosphere
The discussion centers on the absorption of atmospheric water into a solution when cooling occurs in an open container. It is established that if the container's temperature drops below the dew point, condensation can form on the walls and potentially drip into the solution, altering its concentration or introducing impurities. The extent of this absorption is contingent upon the solution's water absorption capacity and the specific reactants involved. Detailed experimental conditions are necessary for precise analysis.
  • Understanding of dew point and condensation principles
  • Knowledge of aqueous and organic solution properties
  • Familiarity with experimental design and reactant interactions
  • Basic principles of solution concentration changes
  • Research the effects of humidity on solution properties
  • Study the principles of condensation in open systems
  • Explore methods for measuring water absorption in solutions
  • Investigate the impact of impurities on solution behavior
Chemists, laboratory technicians, and researchers involved in experimental chemistry, particularly those studying solution properties and the effects of environmental conditions on chemical reactions.
when cooling a solution, if the container is open, is it possible that some water from the atmosphere can be absorbed into the solution? and if so, can there be a significant amount of absorbance (i.e enough to alter some properties of the solution) ?
I'm trying to explain some results i got in an experiment...i think i may be on the right track with this, but i thought i'd better be sure...anything else that's relevant would be good too
ta
Chemistry news on Phys.org
Well, it depends on the water absorption capacity of your solution. Upon cooling, it is however possible to observe the interference of humidity.
But you'll need to give some experimental details about your event, especially, the reactants.
Regards, chem_tr
The way I see it, if your container gets colder than the dew point, you will have condensation upon it. If the container is open, then there's a good chance that the condensation along the inside walls will drip into the solution.
If this is an aqueous solution, you will merely change its concentration. If it's organic, you could be introducing an impurity.
To give you better advice, we will need to know what exactly you have, how it is being cooled, temperatures, etc.
  • · Replies 17 ·
