Uncertainty relation: minimum value
The problem involves demonstrating the minimum uncertainty in the position of an electron given its speed in terms of the uncertainty principle and relativistic momentum. The context is rooted in quantum mechanics and special relativity.
  • Participants discuss the relationship between position uncertainty and momentum, questioning the validity of assuming that the electron can reach the speed of light. There is an exploration of how momentum varies and its implications for uncertainty in position.
There is an ongoing examination of the assumptions made regarding the speed of the electron and its implications for the uncertainty calculations. Some participants express agreement with the analysis presented, while others suggest reconsidering certain assumptions. The discussion remains open without a definitive conclusion.
Participants note the constraints of the problem, particularly the assumption that the electron cannot reach the speed of light, which influences the calculations of momentum and uncertainty.
fluxions
Show that the smallest possible uncertainty in the position of an electron whose speed is given by [tex]\beta = v/c[/tex] is [tex]\Delta x_{min} = \frac{h}{4 \pi m_0 c}\sqrt{1-\beta^2}[/tex]
Since [tex]\Delta x \Delta p \geq \frac{\hbar}{2}[/tex], we see that [tex]\Delta x_{min}[/tex] occurs when [tex]\Delta p[/tex] has its greatest value.
Relativistically, [tex]\Delta p[/tex] is:
[tex]\Delta p = \Delta ( \frac{m_0 v}{\sqrt{1 - \beta^2}}) = ... = (1-\beta^2)^{-3/2} m_0 \Delta v[/tex]Now the greatest value of [tex]\Delta p[/tex] occurs when [tex]\Delta v[/tex] is c.
Hence
[tex]\Delta x_{min} = \frac{h}{4 \pi m_0 c} (1 - \beta^2)^{3/2}[/tex].
My exponent for gamma is incorrect. Where did I go wrong?
You can apply this only when [tex]\Delta v[/tex] is very small. Here you set [tex]\Delta v = c[/tex], not small at all! In this case, [tex]v_{max}=c[/tex] and [tex]v_{min}=0[/tex], which correspond to p = infinity (!) and p = 0 respectively. Obviously [tex]\Delta p = infinity[/tex], which results in [tex]\Delta x = 0[/tex], and that's not what we want. Therefore I think that we should reconsider the assumption that the electron may reach to v=c.
I don't get the needed result, but let me present my opinion and see if we can proceed from that. Assume that the electron is free electron (it's free from any potential field). Due to the law of energy conservation, its kinetic energy cannot increase, so [tex]v = const[/tex] and thus [tex]|\vec{p}| = const[/tex].
However momentum [tex]\vec{p}[/tex] may point to any direction, which leads to the fact that [tex]p_x[/tex] varies. Since p=const, the largest uncertainty of [tex]p_x[/tex] is: [tex]max(\Delta p_x) = 2p[/tex]. Thus: [tex]min(\Delta x)=\frac{h}{4\pi m_o v}\sqrt{1-\beta^2}[/tex].
Oops. Yeah, my approximation is definitely not justified; I feel rather silly for using it.
[/QUOTE]
However momentum [tex]\vec{p}[/tex] may point to any direction, which leads to the fact that [tex]p_x[/tex] varies. Since p=const, the largest uncertainty of [tex]p_x[/tex] is: [tex]max(\Delta p_x) = 2p[/tex]. Thus: [tex]min(\Delta x)=\frac{h}{4\pi m_o v}\sqrt{1-\beta^2}[/tex].[/QUOTE]
Ok, I agree with your analysis for the most part.[tex]max(\Delta p_x) = 2p[/tex] holds for each value of p, hence v. We can take the max (supremum, actually, since v cannot equal c) of this max by sending v to c. This gives the desired result.
That may be a good estimation :rolleyes:
  • · Replies 24 ·
