Thread Closed
Body whose temperature is constant but not the same all over. Thermal equilibrium?
Share Thread Thread Tools
Oct2-10, 09:52 AM   #1
Can one say a body which has the conditions above mentioned be in thermal equilibrium? How does one apply the definition of temperature equilibrium to this situation?
(Physically I think it's possible for a body to be in this situation if some part of it receives heat from the outside and another loses heat)
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Oct2-10, 10:46 AM   #2
Interesting question. I guess it's a matter of what you mean by thermal equilibrium. In many textbooks they say thermal equilibrium is when the macroscopic state variables (temperature, pressure, density,...) of the system are constant over time. In this sense you can say that your system is at equilibrium. But if you consider the whole isolated system your subsystem belongs to, this is not at equilibrium. The flow of heat between all the parts of the isolated system cannot be steady forever, but will forcefully vary over time, and finally vanish when all the parts of the complete system will be at the same temperature (this because an infinite heat reservoir doesn't exist).
Oct2-10, 09:26 PM   #3
Recognitions:
Quote by tme92 View Post
The body is not in equilibrium, but may have steady-state conditions. Our bodies have these conditions: core temperature 98.6 F, skin temperature closer to ambient air temperature.
All this means is that there is a steady flow of heat, and T(x,t) = T(x).
Thread Closed
Thread Tools
Similar Threads for: Body whose temperature is constant but not the same all over. Thermal equilibrium?
Thread Forum Replies
Finding Thermal Equilibrium Temperature Advanced Physics Homework 16
equilibrium constant varying with temperature...but confused! Biology, Chemistry & Other Homework 3
thermal equilibrium Introductory Physics Homework 4
Effect of raising temperature on equilibrium constant? Biology, Chemistry & Other Homework 1
Thermal equilibrium Introductory Physics Homework 3
