How Does Wood Resistance Affect Bullet Penetration and Stoppage Time?
In summary, the conversation discusses a problem involving a rifle firing a bullet into a block of wood and determining the resistive force exerted by the wood on the bullet, as well as the time it takes for the bullet to come to rest. The equations used include force = mass * acceleration, distance = velocity * time, and final velocity = initial velocity + acceleration * time. After some calculations, it is determined that the time spent in the barrel is not relevant to the problem and that doubling the length of the barrel would not necessarily double the time needed for the bullet to stop.
TylerK
A rifle with a barrel length of 56 cm fires a 10 g bullet with a horizontal speed of 350 m/s. The bullet strikes a block of wood locked in position and penetrates to a depth of 13 cm.
What resistive force (assumed to be constant) does the wood exert on the bullet?
How long does it take the bullet to come to rest?
f = m * a
d = v * t
vf = vi + a * t
Force of wood on bullet = 4700 (was confirmed correct)
f = m * a
a = -471154 N
I tried
D = v * t1 for the barrel
.55 = 350 * t1
t1 = 350 / .55 = .0016 seconds
For the wood
vf = vi + a * t2
0 = 350 - 471154 t2
t2 = 350 / 471154 = .000743 seconds
t1 + t2 = .002343 seconds which is wrong.
If the barrel was twice longer, would it change time needed to stop the bullet?
You wrote
TylerK said:
a = -471154 N
Are you sure N is a correct unit of acceleration?
Yes it is m/s^2 I mistakenly typed N. I tried to brake the problem up into 2 parts.
Part 1: Time of bullet in barrel, with 0 acceleration so
d = v * t
.56m = 350 m / s * t
t = .56 m * s / 350 m = .0016 seconds
Part 2: Time it enters the wood until the bullet stops.
vf =vi + a * t
0 = 350 m/s + (-471154 m / s^2) t
-350 m/s * (1/-471154 m/s^2) = t
t = .000743 seconds
I apparently do not add these 2 times together, as the combined result is incorrect.
If the barrel was twice as long, wouldn't it double the amount of time the bullet was in the barrel, as accounted for in the first part? (assuming no friction in the barrel)
You are missing the point.
Is the time spent in the barrel in any way relevant?
It is important to note that the equations used in this attempt at a solution are only valid for motion in a straight line with constant acceleration. In this scenario, the bullet experiences a resistive force from the wood that is not constant and also changes direction as it enters the block of wood. Therefore, the equations used may not accurately represent the motion of the bullet in this situation.
To accurately determine the time it takes for the bullet to come to rest, a more complex analysis would be needed, taking into account the varying resistive force and changes in direction. Additionally, the type of wood and density of the block may also affect the resistive force and therefore impact the calculation.
It would also be important to consider the conservation of energy in this scenario. The kinetic energy of the bullet before impact would be equal to the work done by the resistive force of the wood in stopping the bullet. This could potentially provide a more accurate estimate of the time it takes for the bullet to come to rest.
Further experimentation and data analysis would be necessary to accurately determine the resistive force and time it takes for the bullet to come to rest in this scenario.
1. What is a bullet in a block of wood?
A bullet in a block of wood is a demonstration commonly used in physics to illustrate the conservation of momentum and energy. It involves firing a bullet into a block of wood and observing the resulting motion of the block.
2. How does a bullet in a block of wood demonstrate the conservation of momentum?
In this demonstration, the bullet has a certain amount of momentum as it is fired into the block of wood. When it becomes embedded in the wood, the block gains an equal and opposite momentum, resulting in a net momentum of zero. This illustrates the principle of conservation of momentum, which states that the total momentum of a system remains constant unless acted upon by an external force.
3. What can we learn from a bullet in a block of wood experiment?
Aside from illustrating the conservation of momentum, this experiment can also demonstrate the conservation of energy. The bullet has kinetic energy as it is fired, which is converted into potential energy as it becomes embedded in the wood. This conversion is accompanied by the release of heat and sound energy.
4. How does the type of wood used affect the results of the experiment?
The type of wood used can affect the results of the experiment in several ways. A softer wood may result in a deeper penetration of the bullet, while a harder wood may cause the bullet to ricochet or fragment. The density and thickness of the wood can also impact the amount of energy absorbed by the block.
5. Are there any safety precautions to consider when conducting a bullet in a block of wood experiment?
Yes, there are several safety precautions that should be taken when conducting this experiment. It is important to wear appropriate protective gear, such as safety glasses, and to conduct the experiment in a controlled environment. It is also crucial to follow proper gun safety protocols and to have a designated area for firing the bullet. Additionally, it is important to have a fire extinguisher on hand in case of any unexpected fires.
12K
