Register to reply
Proving that a set is non-empty and bounded above.
by silvermane
Tags: analysis, bound, proof, set theory, supremum
Share this thread:
silvermane
#1
Oct3-10, 03:08 PM
PF Gold
silvermane's Avatar
P: 117
Let A = {x: x^2 + 3x + 2 <0}. Prove that this set is non-empty and bounded above. What is the least upper bound? Is it bounded below?
3. The attempt at a solution
Well, solving for the zeros and understanding that between the zeros, we satisfy our values of x's, I have that the set is (-2,-1) which has both an upper bound and lower bound. The least upper bound would be -1 as well.
I understand what's it's asking, but I'm having trouble writing a proof and would like it if I could perhaps have proof-writing tips.
Thank you so much for your help and tips in advance! :)
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
╔(σ_σ)╝
#2
Oct3-10, 03:25 PM
╔(σ_σ)╝'s Avatar
P: 849
I suppose for you could do following.
Show that -1+ e (epsilon) cannot be the suprema because there is no element in the set greater than -1 + e - e/2. Which is a property of the suprema of a set . That is, if supA is the supremum of a set there exist x in A such that x>supA- e.
What this would succeed in showing is that any number greater than -1 is not a supremum. You should also argue that-1-e is not even an upper bound of the set.
Do the same for the infima with a slight modification.
╔(σ_σ)╝
#3
Oct3-10, 03:37 PM
╔(σ_σ)╝'s Avatar
P: 849
Well so much for reading the question lol. You don't even need to prove anything regarding infima and suprema :-) You could proof it for fun if you like.
All you have to prove is that is non empty which is easy. Consider x= - 1/2.
Then you have to show it bounded above. This can be done by showing that
any element greater than 1 or 2 (pick any) is not in the set. This implies they are upper bounds.
JonF
#4
Oct3-10, 03:37 PM
P: 617
A isn’t empty because: -1.5 is in the set.
Consider 1^2 + 3*1 + 2 = 6, so clearly 1 isn’t in A. Polynomials are continuous functions so 1 then either has to be an upper or lower bound. Since -1.5 is in the set 1 must be an upper bound.
Let f(x) = x^2 + 3x + 2, Let b = -1 + ε. Consider b^2 + 3b + 2. = (-1 + ε)^2 +3(-1 + ε) +2 = 1 -2ε + ε^2 - 3 + 3 ε +2 = ε^2 + ε.
Thus if c > -1 then it isn’t the least upper bound, since -1 is an upper bound. If c < -1 then clearly an ε for b in A can be chosen where c < b. Thus the suprema is -1.
╔(σ_σ)╝
#5
Oct3-10, 03:44 PM
╔(σ_σ)╝'s Avatar
P: 849
@JonF
Please don't give full solutions to problems. It does not help people learn.
Btw I think you made an error in your post. You said -1.5 is a upper bound; I don't know what you meant since it is neither an upper or lower bound:-).
And both of us did not read the question fully. We are not supposed to prove the suprema.
silvermane
#6
Oct3-10, 04:41 PM
PF Gold
silvermane's Avatar
P: 117
Quote Quote by ╔(σ_σ)╝ View Post
@JonF
Haha wow! Thank you for the helpful hints, and concern about learning for one's self. :)))
Thank you as well Jon, though I didn't need a straight answer. I like to work myself and have that great feeling of "look what I can do" lol
silvermane
#7
Oct3-10, 04:43 PM
PF Gold
silvermane's Avatar
P: 117
Yeah, it's much easier than I thought too. I think I need to read the question more fully
:P
Register to reply
Related Discussions
Is empty set open?bounded?perfect?compact? Calculus 12
Proving exp function is bounded and not extended continuously. Calculus & Beyond Homework 6
Proving an Autonomous First Order ODE is Bounded Calculus & Beyond Homework 1
Proving that f is bounded on R Calculus & Beyond Homework 2
Proving that a function is monotonic and bounded.. Calculus & Beyond Homework 8
