Calculating the pilot's effective weight at the bottom and top of a circle
  • Thread starter Thread starter bfpearce
    Circle Weight
The discussion focuses on calculating the effective weight of a jet pilot during a vertical loop maneuver. The pilot's aircraft moves at a speed of 1500 m/s, and the minimum radius of the loop is determined to be 2.7 x 103 meters to ensure centripetal acceleration does not exceed 6.6 g's. The second part of the problem involves calculating the effective weight of a 68 kg pilot at both the bottom and top of the loop, requiring an understanding of the forces acting on the pilot and the application of free body diagrams.
  • Centripetal acceleration concepts
  • Free body diagram analysis
  • Newton's second law of motion
  • Basic physics of circular motion
  • Study centripetal acceleration calculations in circular motion
  • Learn to draw and analyze free body diagrams
  • Explore the application of Newton's laws in dynamic systems
  • Investigate the effects of gravitational forces on objects in motion
Aerospace engineers, physics students, and anyone interested in the dynamics of forces acting on pilots during aerial maneuvers.
bfpearce
Ok so there are two part to this problem:
Info: A jet pilot takes his aircraft in a vertical loop
Part 1: If the jet is moving at a speed of 1500 at the lowest point of the loop, determine the minimum radius of the circle so that the centripetal acceleration at the lowest point does not exceed 6.6 's.
I got the answer of this one to be 2.7 X 10^3
Part 2: Calculate the 68- pilot's effective weight (the force with which the seat pushes up on him) at the bottom of the circle, and at the top of the circle (assume the same speed).
I honestly don't even know where to start with this one. Can somebody help??
What are the forces acting on the pilot at the bottom? Draw a free body diagram. What must the sum of all forces be equal to in any free body diagram? What is the acceleration of the pilot at the bottom? Write out the equation for the sum of all forces. What must the magnitude of the normal force be in order for the forces to add up to the total net force?
Now do the same thing for pilot at the top of the loop.
AM
