Hot-air balloon (kinematics question)
  • Thread starter Thread starter Sean1218
    Balloon
The problem involves a hot-air balloon rising at a constant velocity of 4.0 m/s, from which a can of pop is dropped at a height of 4.0 m. The question seeks to determine the time it takes for the can to reach the ground, incorporating concepts from kinematics and uniform acceleration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the initial velocity of the can, questioning whether it should be considered as 0 m/s or 4.0 m/s due to the balloon's motion. There is also confusion regarding the correct form of the displacement equation and how to apply the variables correctly.
Some participants have attempted various approaches but express uncertainty about the correct values to use in the equations. Guidance has been offered to find a more general equation for displacement under constant acceleration, with emphasis on identifying initial conditions and ensuring consistent sign conventions.
Participants are navigating potential confusion regarding the setup of the problem and the application of kinematic equations, with specific attention to the initial conditions and the effects of gravity on the can after it is dropped.
Sean1218
A hot-air balloon is rising upward with a constant velocity of 4.0 m/s. As the balloon reaches a height of 4.0 m above the ground, the balloonist accidentally drops a can of pop over the edge of the basket. How long does it take for the pop can to reach the ground?
d = v2t - 1/2at^2
other uniform acceleration equations
Tried a few different things, but nothing seems to work out. I'm not sure if the pop can starts at v1 = 0 m/s or at v1 = 4.0 m/s because of the rising balloon. It falls from 4.0 m and gravity is -9.8 m/s^2.
That's 4 values, but which of the 4 do I use? I didn't get the right answer from just plugging them in, so I'm not sure what else I can do.
d = v2t - 1/2at^2
Just to eliminate potential problems, in the velocity term, do you mean v2 t, (v2)t, or something else? The equation is either incorrect as written or at least confusing.
This should be an equation for displacement d(t) as a function of:
1. time, t
2. displacement at t=0, d0
3. velocity at t=0, v0
4. acceleration, a.
Try to find the appropriate equation. It's close to the one that you wrote.
What was the velocity of the can before it was dropped?
Sorry, meant v2 as in velocity #2.
d = v#2(t) - 1/2at^2 where v#2 = 0, d = 4, a = -9.8, solve for t
if I do it with v#1 instead (v#1 = 4.0), I still don't seem to get the right answer. I must just be plugging in the wrong values, but I've tried everything I can think of.
and the velocity of it before it was dropped was 4.0 m/s, so I guess that'd be v#1, yea.
I told you to find a more general equation, since you're having trouble identifying how to plug the information given into the equation that you're using. Find the most general equation for displacement at constant acceleration (in your notes or text) and identify the initial and final values that you need to put in.
i thought that was what I did :confused:
It's not, the most general equation is
d(t) = d0 + v0 t + (1/2) a t2,
where
d(t) is the displacement after the time t
d0 is the displacement at t=0
v0 is the velocity at t=0
a is the constant acceleration.
It's conventional to measure displacement as increasing in the vertical direction. The signs of the initial velocity and acceleration must be identified consistent with that convention.
Try identifying all of the quantities in the equation above in terms of the information given.
