Capillary Tube and Surface Tension
In summary, the question asks for the length at which a glass capillary tube must be immersed in a liquid for the liquid level inside and outside the tube to become equal. The formula for capillary rise is used to determine this length, and the formula for the radius of a meniscus is discussed. The difference between h1 and h2 is explained, and the absurd result obtained when solving the equation is noted. The observations about this problem include the fact that the water will not rise in a closed tube due to pressure differences and the difficulty of achieving equal levels inside and outside the tube within a certain distance.
zorro
1,384
A glass capillary sealed at the upper end is of length 0.11m and internal diameter 2 x 10^-5 m. The tube is immersed vertically into a liquid of surface tension 5.06 x 10^-2 N/m. To what length has the capillary to be immersed so that the liquid level inside and outside the capillary becomes the same? What will happen to the water level inside the capillary if the seal is now broken?
Let A be the area of cross section of the tube. Initially, the volume of air inside the tube is AL. Here pressure is Patm.
Where L is the length of the tube.
When is it dipped, capillary rise takes place till some height.
Let it be dipped through a distance 'x' when the level of water equalises outside level. Volume of air present= A(L-x)
I don't know what will be the pressure at this stage. Is it equal to Patm?
When the seal is broken, the water will rise upwards and adjust its meniscus ( I calculated the capillary rise as 1.03m). What is the formula for the radius of meniscus?
When the tube is dipped, a bubble is formed at the tip. Excess pressure inside the bubble is 2T/R. The water will start rising when ρ*g*h1 = 2T/R, where h is the depth to which the tube is dipped. At this stage pressure P inside the tube is (Po + ρ*g*h1) and volume V = A*L.
When the levels of the water inside and outside are equal, you can apply P1V1 = P2V2
(Po + ρ*g*h1)* A*L. = [Po + ρ*g*(h1 + h2)]*A*(L.- h2)
What is h2 in your expression?
Is the formation of bubble alone responsible for capillary action? I think water rises even when there is no bubble formed.
In the formula for capillary rise,
H=2Tcos(theta)/rρg, it doesnot depend on the height to which the tube is dipped. Then how can you say that water will start rising when ρ*g*h1 = 2T/R?
Thanks for your reply
When you try to dip the closed tube in the water, air pressure will not allow the water to rise. So only the middle portion of the water in the tube will rise forming a hemispherical liquid drop, with excess pressure 2T/R. When you dip the tube further, due to increased air pressure radius of the meniscus decreases. At a certain depth the liquid surface becomes flat. At that stage ρgh = 2T/R. If you dip further the liquid will start rising.
Till h1 the liquid is not rising in the tube. When you dip further till h2, the liquid level inside and outside will be the same.
I still don't understand the difference between h1 and h2. Till h1 the liquid is not rising in the tube, which means that the level of water in the tube and outside is same. What I understood is that h1=h2!
Take a test tube and dip in the water up side down. And push it inside gently. You can see that level of water inside and out side are different.
Similarly in the case of closed capillary tube, because of the surface tension, water will not rise in tube until pressure due the depth water overcome the pressure due to surface tension, which is 2T/R. In the problem I have equated it to ρ*g*h1, where h1 is the length of the tube in side the water. When you push the tube further inside the water, the water will start rising up. At the depth of (h1 + h2) the level of water inside the tube will be in level with outside water.
On solving your equation, I got
h2 = L - h1 - Po/ρg
h1=2T/rρg h1=1.03 m
As L=0.11, It means that the tube is dipped far below the surface of water.
on Solving I got h2 as -10.92m, which seems absurd to me.
My observations about this problem.
1) If the given capillary tube is open and dipped in the tube, the water will rise up to the top and stop there. There will be no over flow.
2) If you dip the closed tube, the pressure inside the tube be the atmospheric pressure. But the pressure at the bottom due to the meniscus will be less then the atmospheric pressure. So the water will not rise in the tube.
3) by dipping the tube further, within 11cm it may not be possible to achieve the equal level inside and outside.
1. What is a capillary tube?
A capillary tube is a small, thin tube with a narrow internal diameter, typically less than 1 mm. It is often made of glass or plastic and is used in various scientific and medical applications, such as measuring small volumes of liquids or delivering precise amounts of medication.
2. How does surface tension affect liquids in a capillary tube?
Surface tension is the force that causes the surface of a liquid to behave like a thin, elastic skin. In a capillary tube, this force is responsible for pulling the liquid up against gravity and causing it to rise up the tube. This is known as capillary action and it is due to the strong adhesive and cohesive forces of the liquid molecules.
3. What factors affect the height to which a liquid rises in a capillary tube?
The height to which a liquid rises in a capillary tube is affected by several factors, including the diameter of the tube, the surface tension of the liquid, and the angle of contact between the liquid and the tube. Additionally, the type of liquid and the presence of any impurities or contaminants can also impact the height of capillary rise.
4. Can capillary tubes be used to measure surface tension?
Yes, capillary tubes can be used to indirectly measure the surface tension of a liquid. By measuring the height to which the liquid rises in the tube, the surface tension can be calculated using the Young-Laplace equation. This method is commonly used in scientific experiments and quality control procedures.
5. What other applications does capillary action and surface tension have?
Capillary action and surface tension have a wide range of applications in various fields of science and technology. Some common examples include ink pens, paper towels, and plants relying on capillary action to transport water from their roots to their leaves. It is also used in microfluidics, chromatography, and the production of certain materials such as foams and emulsions.
  • Mechanics
