Register to reply
Heat transfer, heat from current
by Frostfire
Tags: current, heat, transfer
Share this thread:
Frostfire
#1
Oct5-10, 07:01 PM
P: 50
Is there a relation that connects a current with the diameter of a material for efficient transfer of thermal energy.
I say diameter as I think its safe to assume heat leaves radially given a uniform material.
I am also looking for a relation between resistance of a material and heat generated under high current loads. I know the basic ones but I seem to remeber something about them not being accurate given high current
Any helps appreciated
Phys.Org News Partner Engineering news on Phys.org
Printing the metals of the future
New gadget helps the vision-impaired to read graphs
3D printing helps designers build a better brick
Mapes
#2
Oct24-10, 10:41 AM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
What exactly do you mean by "efficient transfer of thermal energy" here? (Highest temperature per unit power? Voltage? Something else?) It will affect how you attack the problem.
You may have some luck searching "resistivity" + "temperature" for your material of interest.
Frostfire
#3
Oct24-10, 04:14 PM
P: 50
thermal energy per power was my first thought
Mapes
#4
Oct24-10, 05:48 PM
Sci Advisor
HW Helper
PF Gold
Mapes's Avatar
P: 2,532
OK, that's going to be relatively straightforward: the efficiency is just
[tex]\eta=\frac{I^2R_L}{I^2R_L+I^2R_S}=\frac{R_L}{R_L+R_S}=\frac{1}{1+R_SA/\rho L}[/tex]
where [itex]I[/itex] is the current, [itex]R_L=\rho L/A[/itex] is the load resistance (the resistance of the heater), [itex]R_S[/itex] is the source resistance (the resistance of the power supply and wiring), [itex]\rho[/itex] is the resistivity of the heater material, and [itex]L[/itex] and [itex]A[/itex] are the length and cross-sectional area of the thermal heater.
This is essentially the principle of power matching; you maximize power transfer when the load resistance matches the source resistance and the source resistance is minimized. Does this answer your question?
Register to reply
Related Discussions
Transient heat transfer in heat exchangers Mechanical Engineering 2
Rate of heat transfer / specific heat General Physics 2
Is the overall heat transfer coefficient constant for a certain heat exchanger? Advanced Physics Homework 0
Heat transfer and latent heat Introductory Physics Homework 5
Rate of heat transfer and heat conductors General Physics 3
