Light, gravity, and red shift.
The discussion centers on the relationship between light, gravity, and redshift, exploring how gravitational effects might influence the energy and trajectory of photons as they travel through the universe. Participants examine the implications of these effects on the observed redshift of light from distant stars, considering both gravitational influences and the motion of stars.
  • One participant posits that photons have their own gravitational field and suggests that their paths are altered by gravitational fields, leading to energy loss and redshift due to gravitational waves.
  • Another participant clarifies that in general relativity, the world-line of a photon is considered a "straight" line, implying that photons do not deviate significantly from their paths in interstellar space.
  • Some participants argue that photons behave like massless "test particles" and do not radiate gravitational waves, even under extreme conditions such as orbiting a black hole.
  • Calculations are mentioned as a method to determine the causes of redshift, with emphasis on the long timescales involved in energy loss for photons.
Participants express differing views on the mechanisms behind redshift, with some supporting the idea of gravitational effects causing energy loss, while others argue that photons do not radiate gravitational waves and behave as test particles. The discussion remains unresolved regarding the primary cause of redshift.
The discussion includes assumptions about the behavior of photons in gravitational fields and the applicability of certain approximations, which are not fully explored or agreed upon by participants.
mrspeedybob
Light responds to gravitation. Light has momentum.
Given these two postulates it follows that if a photon passes a massive body both the photon and the body will be effected, though admittedly the effect on the massive body will be extremely slight.
Put another way, a photon has its own gravitational field.
Now a photon traveling through the universe is not going to travel in a straight line, it's course will be constantly altered by the gravitational fields it goes through. Since it is constantly changing directions it seems that some of its energy would be radiated away as gravitational waves. Since its velocity is fixed this would mean that it would shift to a lower energy frequency. The longer the photon traveled through the universe the more energy it would lose and the more red shifted it would become. How do we know that the red shift in light from distant stars is shifted due to the star moving away and not due to losing energy in the form of gravity waves?
The world-line of a test particle, such as a photon, is essentially the definition of a "straight" line in general relativity. A good introduction to this kind of thing is Relativity Simply Explained, by Martin Gardner.
By doing calculations.
The lighter a particle is, the more does it resemble a massless "test particle", i.e. a hypothetical particle which doesn't affect spacetime at all. bcrowell is talking about such a test particle.
Photons are already very light. The worst thing - in terms of acceleration - that can happen to a photon is to orbit around a small (~sun-sized) black hole. It's at the very least some 20 orders of magnitude worse than what happens to a photon in interstellar space.
Even then, if the usual Quadrupole approximations still hold for a photon, they lose a significant amount of energy at a timescale of 10^60 s (for optical photons), which is ridiculously longer than the age of the universe.
IOW: they behave like test particles and don't radiate gravitational waves.
Thank you for the reply. That makes sense.
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 46 ·
  • · Replies 132 ·
9K
  • · Replies 19 ·
  • · Replies 30 ·
