Thread Closed
Final Velocity with barely anything AP Phys help
Share Thread Thread Tools
Sep18-04, 08:21 PM   #1
A boy fires a "BB" gun at an angle of 28o above the horizontal. The "BB" strikes a target that is a vertical distance of 1.6 meters above and 12.8 meters to the right of the muzzle (exit point) of the gun. Assuming the bullet has a negative vertical velocity when it strikes the target, calculate the bullet's velocity when it leaves the gun.
i tried everything that i could think of, using trig to figure out
Vx=Vy/tan(28) and therefore Vy/tan(28)=12.8
anything that i would plug into the y=VoT + 1/2(a)(Tsqrd) i would get a negative square root
Thanks in Advance
Anshu
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Sep18-04, 08:42 PM   #2
Welcome to PF Anshu...
Well the obvious line of attack for such a problem would be to write the expressions for the horizontal and vertical distances in terms of time and eliminate time to get a trajectory equation of the form,
[tex]y - y_{0} = (x-x_{0})\tan \alpha -\frac{1}{2}\frac{g(x-x_{0})^{2}}{V_{0}^2}\sec^2\alpha[/tex]
and then plug in all that you have to solve for the initial velocity. (First, try and derive the above equation to convince yourself that it is true).
The other method is to solve for Vx and Vy somehow and relate them through the angle they make. My question here: What do you think the angle between Vx and Vy will be at the time the shot hits the wall? Will it be 28 degrees? Are you sure of that?
Also, you have mentioned an equation for y, the vertical distance. What do you propose to do with it?
Hope that helps...
Cheers
Vivek
Thread Closed
Thread Tools
Similar Threads for: Final Velocity with barely anything AP Phys help
Thread Forum Replies
Final Velocity Introductory Physics Homework 7
Final velocity Advanced Physics Homework 5
Final and Average Velocity Introductory Physics Homework 2
Average and Final Velocity Introductory Physics Homework 5
final velocity of car Introductory Physics Homework 5
