Basic Set Theory (Indexed Collection of Sets)
The discussion revolves around an indexed collection of sets defined as {A_{\alpha} : \alpha\in\Delta} where each A_{\alpha} is a subset of the interval (0,1). The original poster seeks clarification on the properties of these sets, particularly regarding their intersections and the conditions under which the overall intersection is empty.
  • The original poster attempts to understand how the intersection of all sets can be empty while each pair of sets has a non-empty intersection. Some participants explore the implications of limits and the behavior of sequences in the context of set intersections.
Participants are engaging in a productive exploration of the properties of infinite sets and their intersections. Some have provided insights into the nature of limits and the behavior of open sets, while others express uncertainty about their understanding of infinite collections.
There is a noted concern about the original poster's grasp of infinite sets and their properties, which may affect their interpretation of the problem. The discussion includes references to the definitions and behaviors of intersections in both finite and infinite contexts.
Swixi
Give an example of an indexed collection of sets {[tex]A_{\alpha}[/tex] : [tex]\alpha\in\Delta[/tex]} such that each [tex]A_{\alpha}[/tex][tex]\subseteq[/tex](0,1) , and for all [tex]\alpha[/tex] and [tex]\beta\in\Delta, A_{\alpha}\cap A_{\beta}\neq \emptyset[/tex] but [tex]\bigcap_{\alpha\in\Delta}A_{\alpha} = \emptyset[/tex].
None.
I've found a solution that is:
Let [tex]A_{\alpha}=(0, \frac{1}{\alpha})[/tex], where [tex]\alpha\in\Delta=\mathbb{N}[/tex]
and my main problem is that I don't understand how this is possible.
I understand that [tex]A_{\alpha}\cap A_{\beta}\neq \emptyset[/tex] for any alpha/beta because the intersection will always be (0, 1/max(alpha,beta)).
But I don't understand how [tex]\bigcap_{\alpha\in\Delta}A_{\alpha} = \emptyset[/tex] is true. Wouldn't every set in the family have the smallest real in it, because every set would be (0, a)? I feel like I'm probably not thinking about this the right way.
Thanks for any help!
By definition, if x is in the intersection then x is in (0,1/n) for every n in N. Equivalently, 0<x<1/n. As n-> infty, 1/n -> 0. Using the N-epsilon definition of limits we know that if we let epsilon=x then there is a natural N such that 1/N<x. Therefore, x is not in A_N. Contradiction.
The intersection of any finite number of A_\alpha will be (0,min{1/n_1,1/n_2,...,1/n_k}) but if we want to to intersect all of the sets, {1,1/2,1/3,1/4,...} has no minimum.
Essentially we are probing at the properties of strictly decreasing chains of open sets.
Thanks for the help.
When I was working on this, I initially figured that the intersection over all of the sets is empty like you proved (because n-> infinity and 1/n -> 0).
But, if you were to choose that set "at infinity" (which makes [tex]\bigcap[/tex] empty) as your [tex]A_\alpha[/tex], then wouldn't its intersection with any [tex]A_\beta[/tex] be empty too?
Can you explain to me why this is wrong? I understand how this works for any finite amount of sets, but my intuitive understanding of infinite sets feels quite weak.
I don't understand your problem. Maybe you are thinking of this in terms of limits?
[tex]\mbox{lim}_{k\to\infty}\cap_{n=1}^k\left(0,\frac{1}{n}\right)=\mbox{lim}_{k\to\infty}\left(0,\frac{1}{k}\right)=(0,0)=\emptyset[/tex]
Severe abuse of notation.
I think it's just my grasp of infinite sets that is weak.
I suppose I need to do more work with families of sets.
Thanks again.
