Register to reply
Thermodynamics - work in adiabatic, isothermal, isobaric
by eprparadox
Tags: adiabatic, isothermal, thermodynamics, work
Share this thread:
eprparadox
#1
Oct9-10, 09:13 PM
P: 70
21. A quantity of an ideal gas is compressed to half its initial volume. The process may be adiabatic, isothermal, or isobaric. Rank those three processes in order of the work required of an external agent, least to greatest.
A. adiabatic, isothermal, isobaric
B. adiabatic, isobaric, isothermal
C. isothermal, adiabatic, isobaric
D. isobaric, adiabatic, isothermal
E. isobaric, isothermal, adiabatic
2. Relevant equations
3. The attempt at a solution
If I graph these three curves on a P-V axes, it seems to me that the work by the external agent will be positive because the volume is getting smaller. Also, the work is like the area under the curve for any of these processes, and so I get it choice A as my answer.
The isobaric path encloses a rectangle, the isothermal a hyperbola and the adiabat, a path that encloses less area than the isothermal.
I'm only checking because the answer given is E. And I don't know where I'm going wrong.
Thanks a lot ahead of time.
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
aim1732
#2
Oct10-10, 08:01 AM
P: 432
The problem lies in what you treat external work as. The most accepted convention-well at least in my part of the world-is that work energy coming in the system is negative hence the inequality you built would be reversed.Your logic seems good enough.
Register to reply
Related Discussions
Understanding of thermal processes? Classical Physics 2
Isobaric, Isochoric, Isothermal, and Adiabatic Processes Introductory Physics Homework 2
Question on Thermodynamics (adiabatic and isothermal expansions) Advanced Physics Homework 1
Comparison between heat in isothermal and isobaric Introductory Physics Homework 0
Thermodynamics problem; App of 1st law, work, adiabatic processes, and enthalpy Engineering, Comp Sci, & Technology Homework 3
