| Thread Closed |
applying a force perpendicular to an object moving in the x direction. |
Share Thread |
| Oct12-10, 08:05 PM | #1 |
consider an object moving in the x direction.(1) I f you were to apply a force perpendicular to the x direction, would the magnitude of the velocity of the object in the x direction change?(2) would the magnitude of the velocity in the y direction change.(3) if you were to constantly apply a force perpendicular to the motion of an object, would the magnitude of the velocity of the object change?(4) would the direction of the velocity change? this isnt really a hw question just some stuff im trying to understand... 2. Relevant equations 3. The attempt at a solution (1) i dont think it would,just the direction(2)yes i think so(3)idk(4)yes |
| Oct12-10, 08:18 PM | #2 |
Yes, you have the answers correct for 1, 2, and 4 (although it appears you are unsure). Regarding (3), think of this as a projectile motuion problem.
| Oct12-10, 08:20 PM | #3 |
on 3 it would change in the direction at which you apply force but not in the direction of the motion of the object???
| Oct12-10, 08:54 PM | #4 |
The direction of the applied force is given as always perpendicular to the object, so that does not change, but the applied force causes an acceleration in the vertical direction, and the acceleration requires a change in velocity in the vertical direction.
| Thread Closed |
Similar discussions for: applying a force perpendicular to an object moving in the x direction.
| Force of Wind on a moving object. | Classical Physics | 4 | ||
| Moving an object with constant force(N) in x direction | Introductory Physics Homework | 2 | ||
| Direction of an object when the net force is 0 | Classical Physics | 13 | ||
| Force of a moving object | Introductory Physics Homework | 1 | ||
| force on moving object | Classical Physics | 6 | ||
