Thread Closed
Pigeon hole principle
Share Thread Thread Tools
Oct13-10, 01:55 AM   #1
How many points can be placed in an equilateral triangle where each side is of length 2 such that no 2 points are within 1 of each other?
2. Relevant equations
Need to use pigeon hole principle.
3. The attempt at a solution
I know that there are at least 3. Visually, if you sketch the triangle it looks like there will be a 4. However, I don't know how to prove this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct13-10, 02:39 AM   #2
Quote by auk411 View Post
divide the triangle in 4 area's that can only contain 1 point each
Oct13-10, 05:48 AM   #3
Quote by willem2 View Post
Yes. I'm asking how does one show this. I don't know how to show this. Someone who claims to have the right answer told me that we need to add root 3 over 2 plus root 3 over 6 to get about 1.3.
I am completely lost as to how this is an answer.
Oct14-10, 07:08 PM   #4
Apparently they computed the distance from a corner to a center of the triangle, but this indeed not the answer.
If you can divide the triangle in 4 pieces, such that the maximum distance between 2 points in a single piece is 1, then there can be only a single point in each piece, so the maximum amount of points is 4. You then only have to give a configuration of 4 points to prove that 4 is indeed possible.
Thread Closed
Tags
discrete mathematics, pigeon hole
Thread Tools
Similar Threads for: Pigeon hole principle
Thread Forum Replies
Pigeon Hole Principle problem Precalculus Mathematics Homework 3
a question that should use pigeon hole principle. Linear & Abstract Algebra 15
a question in combinatorics. (perhaps implementation of the pigeon hole principle). Set Theory, Logic, Probability, Statistics 9
need some help with a proof (using the pigeon hole principle) Introductory Physics Homework 4
Pigeon Hole Principle General Math 10
