Thread Closed
Rotating Rockets
Share Thread
Oct14-10, 10:00 PM   #1
Rotating Rockets
Far out in space, a mass1=146500.0 kg rocket and a mass2= 209500.0 kg rocket are docked at opposite ends of a motionless 70.0 m long connecting tunnel. The tunnel is rigid and has a mass of 10500.0 kg.
The rockets start their engines simultaneously, each generating 59200.0 N of thrust in opposite directions. What is the structure's angular velocity after 33.0 s?
2. Relevant equations
center of mass = (m1x1 + m2x2 + m3x3)/m1 + m2 + m3
where m1 = mass of rocket 1, m2 = mass of tunnel, m3 = mass of rocket 3
x(number) = distance to the origin (in this case, rocket one used as origin (set at 0)
Moment of Inertia = m1r1^2 + m2r2^2 (m=mass, r= distance to center of mass)
Moment of inertia of thin, long rod about center = 1/12 ML^2 (M=mass, L=length of rod)
Torque = lengthxForce
angular acceleration = Torque/inertia
angular velocity = angular acceleration x time
3. The attempt at a solution
So, I found the center of mass, and I know it's correct because the previous question asked for it and was found to be correct. It was 41m.
Now, I think I may be calculating my moment of inertia wrong???
I = m1r1^2 + m3r3^2 + 1/12 ML^2
I = 447 938 063.8 kg*m^2
Am is supposed to include the moment of inertia of the tunnel (rod) in this scenario? Obviously I use the mass and their relative distances to the center of mass for the rockets to find their moment of inertia...but do I just add on the moment of inertia of the rod?
My answer was incorrect, so I am trying to figure out what is wrong about my process. I am assuming my moment of inertia is incorrect.
The torque is 70m x 59200N = 4144000 N*m
Please help :)
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Oct15-10, 01:16 AM   #2
Recognitions:
Homework Helper Homework Help
(1/12)*M*L^2 is the moment of inertia of the rod about its center. So to find its moment of inertia about the center of mass, use parallel axis theorem of moment of inertia.
Oct15-10, 02:14 PM   #3
Ok, I did that, but the angular velocity still comes out to be 0.305 rad/sec which is wrong. I still don;t know what else I could be wrong. Any ideas?
Tnet = lF = (70m)(59200) = 4144000 N*m
angular acceleration = Tnet/Itotal
angular acceleration = 9.24x10^-3 rad/s^2
w(omega) = angular accelerationxtime
9.24x10-3 rad/s^2 x 33s
= 0.3052 rad/s
Any help will be very much appreciated :)
Oct16-10, 12:04 AM   #4
Recognitions:
Rotating Rockets
Quote by Tina20 View Post
= 0.3052 rad/s
Net angular acceleration is gives by
[tex]\alpha = F(\frac{1}{m_1r_1} + \frac{1}{m_2r_2} + \frac{1}{m_3r_3})[/tex]
Oct16-10, 12:36 AM   #5
Ok,
so F = lF which is torque, or is it the force of thrust?
I tried both Forces and substituted it into the equation you gave me. I am still not getting a correct answer. I assume r in the equation below is the distance to the center of mass correct? or is it the distance to the centre of the tunnel?
Oct16-10, 01:29 AM   #6
Recognitions:
F is the force of the thrust. F= ma. So a = F/m. angular acceleration α is equal to F/(m*r). All the distances are measured from the center of the mass.
Show your calculations and expected result.
Oct16-10, 10:11 AM   #7
Ok, so F = 59200N
angular a = F (1/m1r1 + 1/m2r2 + 1/m3r3)
angular a = 59200N (1/m1r1 + 1/m2r2 + 1/m3r3) where m1=rocket 1, m2=mass of tunnel, m3=mass of rocket 2. r1 = rocket 1 to centre of mass, r2= centre of tunnel to centre of mass, r3 = rocket 2 to centre of mass.
I solved for angular a and multiplied it by the time and got the right answer! Thank you so much. I don't understand why I was getting it wrong last night...probably too late and I was making a silly mistake.
Thank you for your help!
Thread Closed
Tags
angular speed, rockets, rotating, rotational motion, thurst
Similar discussions for: Rotating Rockets
Thread Forum Replies
Frictional Moment produced by contact between rotating and non-rotating surfaces Introductory Physics Homework 1
mass of the rocket doesnt stay constant General Physics 3
rockets Introductory Physics Homework 10
Rockets Introductory Physics Homework 1
Rockets General Physics 2
