Block attached to string, wrapped around hollow cylinder and free to rotate
The problem involves a 3.20 kg block attached to a string wrapped around a 1.17 kg hollow cylinder with a diameter of 4.08 cm, which rotates freely. The block is released from a height of 1.09 m, and the goal is to determine its speed upon hitting the ground. The energy conservation equation used is Mgh = 1/2(Iw^2) + 1/2(mv^2), where I is the moment of inertia of the hollow cylinder (MR^2) and w is the angular speed related to linear speed (w = v/r). The final calculation yields a speed of 7.64 m/s, but the solution is identified as incorrect, indicating a potential error in the equation setup.
  • Understanding of energy conservation principles in physics
  • Familiarity with rotational dynamics and moment of inertia
  • Knowledge of angular and linear velocity relationships
  • Basic algebra for solving equations
  • Review the concept of moment of inertia for different shapes, particularly hollow cylinders
  • Learn how to derive relationships between angular and linear motion
  • Study energy conservation in systems involving both translational and rotational motion
  • Practice solving similar problems involving pulleys and rotating objects
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to understand energy conservation in rotational systems.
Tina20
A 3.20 kg block is attached to a string that is wrapped around a 1.17 kg, 4.08 cm diameter hollow cylinder that is free to rotate on an axel through the center. The block is released 1.09 m above the ground. What is the speed of the block as it hits the ground?
Ui = Kf
Mgh = Kcyl + Kblock
Mgh = 1/2Iw^2 + 1/2mv^2 , where w is angular speed and I is moment of inertia
Moment of Inertia of a hollow cylinder is MR^2
w = v/r
so,
Mgh = 1/2(MR^2)(v^2/r^2) + 1/2mv^2
(3.2kg)(9.8)(1.09m) = 1/2(1.17kg)(v^2/(0.0204m^2) + 1/2(3.2)v^2
34.182 = 2.434x10-4 (v^2/4.1616x10-4) + 1.6v^2
140435.497 = v^2/4.16x10-4 + 1.6v^2
140435.497 = v^2( 1/4.16x10-4 + 1.6v)
140435.497 = v^2 (2402.92 + 1.6)
140435.497 = v^2 (2404.52)
58.4 = v^2
7.64 m/s = v
The answer is wrong unfortunately. I must be missing a vital piece of information in my equation?
1) On the second line of your solution there is 1 error.
2) Take a while to examine your equations.
Can you simplify this ?
Mgh = 1/2(MR^2)(v^2/R^2) + 1/2mv^2
  • · Replies 26 ·
